Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: First Opening - Swamp Content
    Jul 2015
    Sparta NJ
    12
    So we bought a house with our first pool last August. I did some research, discovered this site and had the TF-100/speed stir, etc. in hand before we even moved in. Unfortunately, with the move and unpacking, etc., I decided to continue to use the puck feeder and just enjoy the pool and keep the PH in balance. At one point I tested cya at 80 and by the end of last season the filter required constant cleaning. In hindsight I was probably on the verge of an algae outbreak.
    Fast forward to the other day and I opened the pool to this.
    I balanced the PH, tested cya at 40 (decreased substantially over the winter) and started the SLAM.
    Here is a picture of the following morning. I can now see the bottom of the pool, including a large frog who has taken up residence, and I am going to vacuum and brush this afternoon.
    Unfortunately, my filter pressure is on the rise so I have ordered a new one. I may need to do an acid wash before it gets here as spraying the current one off with the hose is not cutting it. Also, I sprayed all of the algae off the mesh cover. Should I be using anything else to clean it before I put it away?
    I will update this post to document my progress.
    Steve
    10,627 gallon, vinyl, 1 1/2 HP Hayward Super Pump, Hayward Star Clear 1200 Cartridge, Hayward H250FDP Heater
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: First Opening - Swamp Content
    Welcome to TFP
    You got a swamp going there
    we have another person almost in the same situation going now.. Your filter, while a little bigger at 120 sq ft is going to be the hardest part of your SLAM.. because it is so small you're going to be cleaning it constantly, watch your pressure and when it raises 25% you need to clean it, it may only last 30 minutes to an hour...
    The cover can be sprayed with a bleach water combo and scrubbed, then let dry before putting up for the summer
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,658
    HI! Did you name your froggy friend? I hope he accepts the eviction notice!
    Casey has you covered on your questions.
    I would love to see more pics of your pool AND area. That looks so neat with those big rocks! I would have to do some rock climbing! Did you buy for the house or the pool?
    Kim
    Jul 2015
    Sparta NJ
    12
    Thanks you both for the input. Froggy is running out of hiding places.
    Here is another picture of the setup
    Previous owner used to jump off the rocks into the pool. If i attempt that it will be when my kids are not watching
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Welcome!
    Those are some great "before" pictures. Clear that thing right and post lots of pictures along the way and you could end up in Inspirational Links
    Jul 2015
    Sparta NJ
    12
    So it's an overcast day today for the most part. Water is still cloudy, but I feel like I am making some great progress from where I was on Friday.
    GeorgiaPoolOwner's Avatar
    Jun 2015
    Canton, GA
    65
    That's starting to look good. Keep up the good work!
    Free form pebbletec finish; Hayward pump, cartridge filter; SWCG - Hayward T Cell 15; K-2006C.
    Apr 2016
    Rockville MD
    43
    The mechanicals are well hidden too!
    20x35 in-ground oval. Wet Edge Luna Quartz finish. Hayes Super Pump with AO Smith V-Green 165 VS motor. Polaris 380. Enersol solar heating with automatic controller. Automated chlorination with Stenner pump.
    Jul 2015
    Sparta NJ
    12
    Today's progress.
    I seem to be losing water unfortunately and I don't think it's from evaporation. No leaks at the equipment pad and the pools was filled 3/4 of the way up the skimmer when I opened it, so should not be the liner. I looked for possible water/leaks in the yard, but I have a long run as all of the equipment is on the side of the house. Also, not exactly sure where the pipes run underground. Guess I will need to start plugging lines to test after I am done with the slam.
    Jul 2012
    Tallahassee, FL
    30,658
    That is such a pretty area! WOW! Did you buy the house or the pool and area?
    Now you and I both KNOW the kids WILL try it the min your back it turned! LOL
    Kim
    Jul 2015
    Sparta NJ
    12
    Quote Originally Posted by kimkats View Post
    Kim
    Thanks! We absolutely love it. We bought for the house and cult a sac location. The pool/landscaping was a bonus, but we always wanted one. True about the kids, but I am not going to give them any ideas...
    Jul 2015
    Sparta NJ
    12
    My guess is another day or two and I will do the overnight/cc test. I tested cc today and it was between .5 and 1.0. I think I am getting there...
    I also think I found my leak which is just at the waterfall. I can easily fix it once I am done with the SLAM and can turn the filter off for a bit.
    Jul 2015
    Sparta NJ
    12
    Test CC at zero twice today. Going to perform the overnight chlorine loss test and hopefully I will be good to go...
    The sun was going down when these pic's were taken, but the water looks clear to me.
    Jul 2015
    Sparta NJ
    12
    lost 1.5ppm overnight.....soo close
    Jul 2012
    Tallahassee, FL
    30,658
    Is it the shadows or is your water a little cloudy? I don't want you to stop too soon.
    Kim
    Jul 2015
    Sparta NJ
    12
    Kim
    Shadows, as the sun was coming down. Will try to get a picture with full sun if the weather cooperates.
    Jul 2015
    Sparta NJ
    12
    Cloudy all day. These are best shots I could get. Hoping to pass the overnight test and give the pump a break....
    Richard320's Avatar
    Jan 2010
    19,074
    That's clearer than some hotel pools I've seen! Doing good!
    Jul 2015
    Sparta NJ
    12
    Zero chlorine loss overnight....I think that's a wrap! Thanks for the help everyone. It's almost swim time...kids will be excited...
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,658
    Love it! Have the kids been in yet???
    Kim
