Thread: PH/TA
    Jun 2013
    Middlesex County/VA
    50
    PH/TA
    Good morning all! I am going into my third season and it just keeps getting easier for me. Pool opening went super easy. Slammed the mild green pooll and got it clear in 48 hours. I know have most everything in check but would like to know how to fix one area.
    CYA 40
    FC 5
    CC 0
    PH 7.0
    TA 100
    As you can see PH is low and TA is at the high threshold. Should I aerate? Add Borax and not be concerned with the TA? Add Acid to lower TA further then aerate?
    Thank you all in advance!!
    Pool Size: 24' Lomart Whispering Wind II 13000 gallons
    Pool Type: Aboveground
    Pump:Hayward 1 1/2 HP Power Flo Matrix 2 Speed
    Filter: Hayward S230T 250lb Sand Filter
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Re: PH/TA
    Id give it a bit of aeration and see how it goes. You can then adjust your TA once you get your pH back in range.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: PH/TA
    +1 aerate, it will bring your PH up and if you are trying to lower TA at about PH 7.5 lower back to 7.2 using MA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: PH/TA
    If the water is clear and warm enough, toss a couple kids in. They'll aerate the water plenty and raise pH.
    TA only needs to be aggressively reduced if the pH rise is too fast, like adding acid every day, or if the pool is in imminent danger of Calcium scaling. Otherwise just keep knocking down pH when it hits 7.8 and TA will go down naturally.
    Jun 2013
    Middlesex County/VA
    50
    Re: PH/TA
    Thank you all!!!
