Thread: need new diving board
    What are the better diving boards, our 8' board split on the bottom and the wood kinda split with the fiberglass. So much for the cannon ball competitions.
    What are the better boards? ours was rated at 250lbs but I noticed there are two pieces of wood on the bottom encompassed by fiberglass maybe one with wood all the way for the width of the board.
    Where is a good place to get diving boards in NJ, I want to get it before next weekend.
    Any help i appreciated
    Kply
    35,000 In-Ground Concrete/Plaster with spillover spa.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: need new diving board
    Bump! OP is running out of time!
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    S.R. Smith is a good board manufacturer. They make some boards that do not have a wood core. I don't know if they have any with more than a 250 lb rating -- check their web site. The board may get less stress with a more flexible mount to the deck.....
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    Thanks guys,
    I called around trying to save shipping but it seems like not many stores even stock a board.
    I ordered the SR Smith board that is solid wood. There seems to be two or three main manufactures of residential boards and they all seem to have similar boards, none go beyond the 250lb limit.
    I will turn the old board into a bench, might be a little ruff.
    I am trying to add a pic, the fiberglass split longitudianlly and the wood has cracked at the bolt the wood board has also split longittudinally is any of this winter damage (I store it in a shed-no heat)[attachment=0:s9hwmafc]pool diving board 006.jpg[/attachment:s9hwmafc]
    Kply
