Thread: Does chlorine tablet matter? Cheapest place to buy?
    samwestx's Avatar
    May 2016
    Weslaco, Texas (DEEP SOUTH TEXAS)
    99
    just pickin you heads!
    chlorine tablet brand*
    15000 gallon pool (15x30 + 7x7 sitting area), IG-Blue Pebble, Sand Filter-Hayward Pro Series, Pump-Hayward Tristar VS pump, Water Test Kit-TF 100, NEW POOL-COMPLETED ON 5/7/16, City Water w/no restriction, Dolphin M400
    Aug 2015
    Folsom Prison, CA
    124
    Re: Does chlorine tablet matter? Cheapest place to buy?
    You should not be using tabs if you are following TFP method.
    Jeff || 19,000g IGP || SwimClear 3025 Cartridge Filter || Hayward TriStar 1.39 THP pump || K-2006 Test Kit || 80% Surface Coverage Heliocol || Hayward Controller || Hayward Phoenix 4X4 || "Solar Rings" || PoolSkim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Right, trichlor tabs will quickly raise your CYA level. More here, Pool School - How to Chlorinate Your Pool
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    IF anyone searches upon this thread and is determined to buy - be wary because some tablet brands contain algaecide like copper so always read the active ingredient label on any chemical you buy. If the packaging doesn't list the active ingredient... don't buy it!
    38,528
    Tablets have their place, but Texas is generally not one of them. Because you do not close and partially drain for the winter or usually get enough rain to counter the rising CYA.
