Thread: Using sand filter with NO sand
    Manny2587's Avatar
    Aug 2015
    Mt. Airy, MD
    11
    Hello all, here's the deal. I have a 26" Pentair Meteor sand filter that's about 20 years old. The sand is original and I've never deep cleaned it. Today, I removed the multiport valve (top mount) and did a deep clean. Long story short, there's was so much gunk in the sand that it would have taken hours for the water to run clean. After an hour, I gave up and decided to just replace the sand. I used a shop vac and got all the sand out. I removed the laterals for inspection and they need to be replaced. The little slots in all the laterals are caked with sand and a few were cracked. So I just ordered new laterals which won't be here until middle-late next week.
    You can see my issue now. My water will be sitting stagnant for days. My question is, can I reinstall the multiport valve with the filter body completely empty and just use the recirculate function? This would be better than nothing. Other wise I will be adding chlorine and brushing a lot I suppose.
    Current levels:
    35,000 gal in ground vinyl
    FC-7
    CC-0
    PH- 7.5
    TA- 110
    CH- 100
    CYA-60
    Borates- 50
    Thanks!
    35,000 gallon in ground vinyl liner
    Hayward 1.5hp super pump
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Using sand filter with NO sand
    it won't filter but it will work just fine
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes.
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,522
    Great question! Kuos to you for asking and getting it on Recirculate to keep the pool moving!
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
