Thread: Black Algae Battle
    Aug 2015
    McKinney, TX
    1
    Black Algae Battle
    I've been battling a black algae problem for about 2 weeks so wanted to get some advice and see if I'm on the right track. I started off with a SLAM and have been running the pump nonstop (other than to clean the filter). Brushing from out of the water 2 or 3 times a day with wire brush. Spots on steps near the surface are gone but still have a good amount in the deep end. I thinking I need to take a swim to brush those deeper spots.
    FC = 15
    CC = 0
    CYA = 40
    CH = 150
    TA = 180
    10,156 IG pebblesheen pool, Jandy Stealth 2 HP, Jandy CL 340 Cartridge,
    Polaris 380 with Polaris Halcyon pump, TF-100 test kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Black Algae Battle
    Welcome to TFP
    Your numbers look great... they are exactly where they should be... so from what your saying your water is clear because you can see the algae in the deep end, correct... Up to SLAM levels you can and it is safe to get into the water, is there no way to brush those spots with your brush? Keeping your FC at SLAM level with almost nothing of the algae left should be pretty easy...
    Are you sure they are not metal stains or something else, just asking to see
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    A pic would be good. But yes, you have to brush to knock of the outer shell/head which is resistant to chlorine. Brushing is key...
    Jun 2015
    Mount Dora, Fl
    11
    When I have that issue I find that a wire brush is ineffective at getting off the spots but I put a pressure wand on my hose and the water pressure does a great job of removing the spots.
    May 2015
    psl,fl
    4
    I do the same, is a quick fix, but I use snorkel and googles to see underwater, when the pressure washer is on you can't see the bottom from the top of the pool.
