Results 1 to 7 of 7
Thread: Using Robot During SLAM?
    Rocket50's Avatar
    Apr 2016
    Nashville, TN
    64
    Good or bad idea to use a robotic cleaner during a SLAM? Worried about long term damage and wear.
    33K, IG, vinyl liner, 15 years old (??), 20x40, 3-8 feet deep, Hayward pump 1.5 HP, Hayward S240 sand filter (300 lbs of sand), Dolphin Triton robotic cleaner, TF-100 test kit.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Using Robot During SLAM?
    the only damage may be if something big was in there that it got stuck on or damaged, other than that it will help your SLAM along faster
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Depends on the cleaner. Some robots have cheaply made parts, like little internal pins that corrode easily with unbalanced water...
    Rocket50's Avatar
    Apr 2016
    Nashville, TN
    64
    OK. Thanks ladies!
    Rocket50's Avatar
    Apr 2016
    Nashville, TN
    64
    Another question. My robot does terrible when the pump is on. Gets stuck on the main drain, rarely gets to the shallow end and can't climb walls. So what is more important, keeping the pump circulating or allowing the robot to do the full job?
    Sep 2013
    Charleston, SC
    538
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Quote Originally Posted by Rocket50 View Post
    Turning the pump off for a couple of hours is not going to create any problems but what's more disturbing is that there's a perceived interaction between your pump and robot. That should not be happening.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
