Thread: Diving Board Suggestions
    Rocket50's Avatar
    Apr 2016
    Nashville, TN
    64
    Hello all. Our diving board broke a couple summers ago and we need to replace it. It is an 8 foot board with three holes. It is very old and the base is heavy metal in a U shape. There is a Frontier II board that might work but the holes don't look like they match up. Thinking I need to replace the base as well. Any suggestions? And does replacing the base mean I will probably have to remove concrete to install a new base?
    33K, IG, vinyl liner, 15 years old (??), 20x40, 3-8 feet deep, Hayward pump 1.5 HP, Hayward S240 sand filter (300 lbs of sand), Dolphin Triton robotic cleaner, TF-100 test kit.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Diving Board Suggestions
    diving boards are fun
    But they are a pain to replace... most have had to call the manufacture and ask what part it is to replace...
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Maybe look into attaching a steel plate to the old base and the new board to that? Drill the holes where you need them. Or rather, have a shop do it.
    Apr 2013
    Sacramento, CA
    2,769
    Who was the original mfg of the board?
    Call the S R Smith customer service number. 800 824 4387 and explain your problem. They are the largest mfg of diving boards left. They make the Frontier II board. They make numerous replacement boards. They may refer you to a dealer.
    Rocket50's Avatar
    Apr 2016
    Nashville, TN
    64
    It's really old. I don't see any writing or stamping for identification at all. I will try SR Smith and see where that takes me. Thanks.
    I can assure you, if I can't find a replacement board, I will hire someone for a new install if needed. Like woodyp's idea though. My brother in law can weld so that might be an option.
