Thread: PSI
    May 2016
    Olive Branch Mississippi
    7
    PSI
    What would a normal PSI gauge reading on a sand filter for a 24ft x 4ft pool whilenot is turned on? Mine is just now getting up to about 5.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: PSI
    when you pump is not on it should read zero and then each filter has a different PSI for a clean filter..
    I hope this helps
    May 2016
    7
    Re: PSI
    Ok thank you.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: PSI
    A better indicator is the pressure from the returns... gauges fail easily.
    38,290
    Re: PSI
    I have never had a gauge fail, the glycerin filled ones are really nice and more robust.
    Although you see a lot more pools than me
    11,969
    Re: PSI
    OMG so much cheap equipment around here. I think I have 4 client's pools that they actually work... If they were paying attention during the off days, I would tell them to replace. but I know they're not
