Thread: How long does everything last?
    Jun 2012
    NJ
    40
    I looked around and didn't see any guidelines on this but it would be helpful to know ballpark for the different pieces of equipment.
    How long do pumps last? Filters? Heaters? pool cleaners/booster pump for pool cleaner?
    Our pool is 10 years old so just trying to budget.
    NJ
    35,000 gallons, DE filter, IG plaster
    TF-100
    Jun 2007
    New Jersey
    653
    Re: How long does everything last?
    Quote Originally Posted by neen01 View Post
    I have a 12-year old pool also in NJ. It depends in some degree if you have an outdoor or indoor platform. If you are outside, like mine, it's less then a sheltered setup. My original motor died last year. Upgraded the WhisperFlo to a 2-speed and should be good for another ten or more. In 70 years of pool experience in this location going back to before I was born, the longest lived motor was about 16 years and the shortest was seven. This year I had to replace all the filter grids, but I see no reason the filter itself should not be good for many more years. I have DE, can't say about modern sand filters. I ran a stainless sand filter from 1973 to 2003, and we had two cast iron ones before that die in less than 15 years each. I don't know about the modern plastic ones. I also have never had a heater so I can't help you there. If I had one, the women would make me use it, and I like my water cool.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Usually about 15 minutes after the warranty expires for me!
    Jun 2012
    NJ
    40
    Thanks! we just replaced the pump this year. it was really loud and they said to replace the motor but i figured 10 years was pretty old so we upgraded to a variable speed one. I will see about the filter grids at the end of this season too then
    Any experience with pool cleaner and the pump for that?
    NJ
    TF-100
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    My first pump lasted over 20 years. My second pump lasted 5 years.
    My old 250k btu heater lasted over 20 years. its just about finished. I expect a new one for $2000 to last 5 years
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Apr 2012
    Warrenton, VA
    27
    My pool just passed the 12 year mark and I have had some repairs. My equipment is located outside.
    Pump - Replaced Jandy Stealth fixed speed after seven years. Still kicking myself for getting another fixed speed...
    Booster (for Polaris 280) - Put it out of its misery after eight years. The noise became unbearable. Replaced with a dolphin and removed booster all together
    Heater - Currently replacing Raypak 406A NG heater. I blame it on myself for not staying on top of pool chemistry, eventually causing the unit to breakdown
    DE Filter - Replaced screens this year. I felt I got some good yardage from these jokers
    Overall, my equipment's longevity surpassed my expectations, especially for being out in the elements.
    2004, 22.5K Gal., 36x18, IG Gunite, 2HP Hayward Pump, Hayward Sand Filter, Raypak 406 NG Heater, Dolphin Supreme M4 Robot, Automatic Cover
