Results 1 to 10 of 10
Thread: Question on Clorine testing.
    May 2016
    La Porte
    25
    I am a previous pool owner, with different home and an above ground pool installed 9/2015. I have some training and experience in the taking and testing of water samples, so this isn't entirely new and I feel confident in my ability to follow procedures. We took cover off pool, water looked clear. We then started pump and it stirred up the sediment on bottom and water clouded up. We then added a gallon of clorine and a one pound package of shock. The water cleared up by the 2nd day.
    Last weekends sample (after running pump about 2 hours)
    fc dark pink and couldnt get sample to go clear
    cc didnt do
    ta 240
    cya 0
    ph 8
    I have been adding ma and aerating to bring TA down..(i have also added stabilizer (cya) in a sock 1.75 lbs last week and added another 1.75 lbs to a sock tonite)
    Tonights sample
    fc light pink and still cant get sample to go clear
    cc did not do
    TA 120
    cya 0
    ph 7.0
    My problem is I cant seem to get an accurate Clorine reading. Does the sample still have a pink tinge or would it be crystal clear...or does my ph have to be about 7.4? Would that affect it that much? I quit at 10 ppm this evening.
    Any advice is welcome and appreciated. Thank you.
    14.6k gal., AG, Pentair SD60 sand filter, Pentair DynII-N2-2 pump, 2 hp/2 speed motor, installed on 9/2015, taylor 2006 test kit, Hayward Diver Dive pool cleaner, well water
    Re: Question on Clorine testing.
    What reagent are you titrating with?
    Test your tap water for fc and cc to verify that the test works.
    If it works, titrate until all pink is gone.
    Support the site
    May 2016
    La Porte
    25
    Taylor R-0871, it has a date code of 05/17, and its a no go on tap water. It did not turn pink when I added the powder R-0870. But at least that tells us that the R-0870 is working. I have well water and there is no clorine in it. (It does turn pink with the pool water), I just cant get (or tell when) it changes to clear. It seems always to have a pink tint.
    Put a couple of drops of bleach in a gallon of tap water and test that. Each drop should be about 1 ppm.
    Maybe your fc is just really high, try using more drops.
    Support the site
    May 2016
    La Porte
    25
    i think my r-0871 is bad. I tried what you suggested. The first time the solution turned pink, I added drops till I got to 30 ppm. I stopped, fiqured the solution was too strong, so I emptied all but one quart of solution and refilled up to one gallon. This time the solution was noticeably lighter in color. Again I stopped at 30 ppm (60 drops). I again diluted as before and the solution had just a tint of pink. I stopped at 20 ppm with no change.
    Donldson's Avatar
    NW Ohio
    2,902
    Are you using a k-2006? Sorry if it says in your signature, can't see it in tapatalk. If so what is the lot number? There have been reports of bad r-0871 in a certain batch lately.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    May 2016
    La Porte
    25
    yes, lot number B1067 exp 5/17 (it may be lot number B10S7) the third digit is hard to tell
    Donldson's Avatar
    NW Ohio
    2,902
    B1067, that's the one. Plug it in the search and you will find half a dozen people with the same issue in the past few weeks.
    Contact Taylor and they will send you a replacement, it sounds like they are aware of the problem.
    May 2016
    La Porte
    25
    yes, thank you
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,541
    Good catch Donald!
    For now you can get one of the cheap tests at Walmart until your new stuff comes in. That will help keep your pool from going green.
    Kim
