Results 1 to 9 of 9
Thread: PSI gauge
    May 2016
    Olive Branch Mississippi
    7
    PSI gauge
    Just moved into home with 24ft x 4ft pool with sand filter trying to get it up and going but the pressure gauge is still at zero when the filter is turned on any ideas of what I need to do?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: PSI gauge
    Hi, welcome to TFP! The pressure gauge is easy to replace. You can get a replacement gauge at most hardware stores for less than $20. The gauge will unscrew from the filter and you can take it with you to be sure to get the correct size.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: PSI gauge
    Gauges are cheap and very expendable.
    May 2016
    7
    Re: PSI gauge
    I actually just replaced it with a new and it is still at zero
    Jul 2015
    Western NC
    115
    Re: PSI gauge
    Maybe you have some valves that are closed or something.
    Post some pictures or at least a more detailed description of your plumbing. How did you "turn the filter on" ?
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: PSI gauge
    Do you have water flow coming out of the return jet?
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,511
    Re: PSI gauge
    If it had a rubber plug with a little rubber tip/nib did you follow the instructions to vent interior air space? Did you use 2-3 wraps of Teflon tape? Pictures please. Does the pump prime successfully? Is the manual air vent open/closed
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
    Jul 2015
    Fremont OH
    42
    Re: PSI gauge
    Two speed pump on low? I have a two speed 1 hp pump, and the psi gauge stays at zero when it runs on low speed.
    Jul 2009
    Houston, Texas
    9,379
    Re: PSI gauge
    That is true if you have a two speed or variable speed pump and run it on low speeds the gauge may not show an increase in pressure. If that is the case set the pump to a higher speed and see if the gauge moves.
    Love TFP? Become a
    TFP Supporter!
