Results 1 to 7 of 7
Thread: I'd like to add lights around my existing pool any option?
    Jan 2015
    San Jose, CA
    236
    I have a kidney shape pool 16x32, the one light isn't really providing me the lighting that I'd like.
    There's an unused return line that I can technically pull power through but it's probably 18" below the water line. Would it be ok if pulled a low voltage 12v line through it and somehow rig a light to it?
    Or perhaps a light low profile enough where I can mount onto the return
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: I'd like to add lights around my existing pool any option?
    all kinds of bad things happen with lights, pool, and voltage and nothing good comes from rigging it
    can you replace the light you have now with a more powerful one?
    Jan 2015
    San Jose, CA
    236
    technically speaking, the pool light is just a hole in the wall with a conduit with a sealed enclosure. I've already replaced my old school lights with some color changing LED ones. I like the idea of hoping a strip light going around the perimeter of the pool.
    SF Bay
    Jul 2015
    Central Valley CA
    1,106
    If the return line is independent of the other returns at least 1.5" and is straight for several inches at the pool they do make nicheless leds, they are not cheep but they do work. You will still need to follow code but given the right circumstances it can be done. Take a look at THIS if it sounds like something you still want to do there are several on here that can link you to the code requirements.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2013
    Sacramento, CA
    2,769
    Atttech is correct. It's possible to do this with nicheless lights if there is enough of a straight run. There are issues with how you access up the back side. But it can be done to code. Your transformer installation must meet certain requirements. You probably need a pool electrician
    A strip led around the pool is NOT permitted because there are no strip led lights with a UL listing for use in pools. No matter what the Internet says if it doesn't have a UL or other listing for use in a pool it can't be in a pool in the USA. Fiber optic strip lights are perfectly ok however.
    Jan 2015
    San Jose, CA
    236
    Thanks for the info. I found the nicheless lights you're talking about but wow $250-500 for one of them. That's hardly even worth it.
    SF Bay
    Apr 2016
    Gainesville Florida
    13
    We put a couple dozen $5 solar lights around our pool, and that did the trick for us. A battery powered camping lamp brings more light to a specific area as needed.
