Thread: How much FC is safe?
    Jul 2012
    Cupertino,CA
    45
    Hi folks.
    I cranked-up the run-time on my pump, in order to get more hours of solar heat generation this week. My plan was to raise the temperature for a birthday party this weekend. (Tomorrow)
    When I increased the run time from 4 hrs to 8 hrs, I didn't think to reduce the % of generation on my SWG.
    Well, I now have 80 degree water, with a FC level of 12!
    It doesn't smell like chlorine, but is that going to be a skin irritant if I allow it to be used?
    Today's #s
    FC= 12
    CC=0
    PH=8.0 ( I added acid to target 7.4)
    TA= 70
    CH=350
    CYA=45
    Temp=80
    What do you think??
    Thanks in advance
    MIKE
    12,000 Gal plaster pool & spa.
    Jandy 2.7HP V.S. e pump, with IQpump control.
    Jandy AquaPure 1400. Jandy PDA.
    Solar heat. Jandy 400btu ng heater.
    Pentair 420 cartridge filter. Polaris 360 sweep.
    Jun 2014
    15,243
    Re: How much FC is safe?
    Hi Mike, You're fine. Even if you were in the middle of a SLAM at your CYA level (round up to 50), you're still below the FC SLAM level. It will drop fast enough once you stop FC production. Have a nice party/weekend.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    your good
    Jul 2012
    Cupertino,CA
    45
    Thanks, Guys.
    I thought so, but wanted to be certain.
    The pool LOOKS AWESOME. It would have sucked to just LOOK at it this weekend.
    Mike
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    You're set, then. Most of us raise the FC a couple points before we have a big crowd in the pool. Might I also suggest you brush thoroughly well in advance? Seems like swimmers hanging off the edges will discover all sorts of dust you didn;t know was there.
