Thread: Alkalinity
    May 2016
    Hopedale, Illinois
    2
    Alkalinity
    When I've tested for my alkalinity I have a reading of 250. My pool is an above ground, 27' diameter, and vinyl. I saw that the ideal alkaline level is 50 - 90+. I was curious, how high it too high? and if 250 is high, what's the best way to reduce it. My PH is 7.8. I am still on the learning curve of maintaining a pool. This is just my second year.
    I appreciate any advice.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Alkalinity
    You're going to have to reduce it in steps by using muriatic acid which will lower your PH and in turn your TA. Aerate to raise PH back up and reduce again. It's gonna be a process. Welcome.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Alkalinity
    Welcome to TFP
    Your high PH is because of the high TA.. You will bring both down using muriatic acid from lowes, HD, or Pool store.. get the 20% baume, not the "green stuff"
    Drop you PH down to 7.2 and when it returns to 7.5 or so take it back down... you can point a return up to make ripples to make it go faster...
    I hope this helps You can read more in pool school.
    May 2016
    Redding/CA
    26
    Re: Alkalinity
    It's also possible that high FC is messing with the TA test. See the link below to see how another user retested and got drastically lower results. I'd double check your TA results before taking a lot of action to fix a problem that might not be there.
    Help with these numbers
    18k plaster IG pool - cartridge filter - Pentair Superflo VS - Taylor K-2006
    Dolphin Nautilus Robotic pool cleaner
    Aug 2010
    Dallas, TX
    4,052
    Re: Alkalinity
    Please post a full set of test results so we can get a better picture of what you are dealing with.
    May 2016
    Hopedale, Illinois
    2
    Re: Alkalinity
    Thanks everyone for your suggestions and help. Tonight when I get home I am going to do a full retest and I will post my results. I figured I'd have to slowly reduce my TA my reading was high. This is only my second year taking care of our pool. I purchased the recommended test kit and I love it.
