Thread: Green, Cloudy Pool
    May 2016
    Carrollton/Texas
    1
    Green, Cloudy Pool
    Hi,
    I am having trouble with my pool being green and cloudy. I have shocked it numerous times and it seems not to do anything. I was told at the pool store that my chlorine levels were very high and the ph was good. They recommended flock. So I am going to brush the pool when I get home and add the flock to the water so hopefully I can then see the bottom in the next couple of days and vacuum when it all falls to the bottom. I am concerned that this will not work since all of the other things we have tried so far have yet to work. Do you have any other suggestions for what I can do to clear up this problem?
    My pool has been green for a couple of weeks now. We have been putting chlorine in it regularly as well as shocking it. When we took a sample up to the pool store they said our chlorine level was very high and the ph was good, but the pool is still green. They recommended putting a double dose of flock in it and then vacuuming when it all falls to the bottom. I am curious about what you guys recommend. Thanks!
    15,000
    inground
    DE Flilter
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Green, Cloudy Pool
    Start with this:
    Pool School - Defeating Algae
    And pick up a test kit. I recommend a TF-100 from TFTestkits.net. Here is a link. TFTestkits.net
    Since you are going to need to SLaM you might as well add the XL option.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,596
    I have combined your two posts for clarity. We recommend you get one of our two suggested test kits, go to Pool School and learn how to SLAM your pool, and stay out of the pool store! Floc is NOT your answer. Can you at least list your pool store test results for us at this point? Welcome.
    May 2016
    Redding/CA
    26
    If you floc now, you'll get rid of a lot of the cloudiness for a very short while. Floc won't kill your algae, so it will grow back and make your pool cloudy again.
    Your problem is likely high CYA (cyanuric acid) that is reducing the ability of your chrloine to kill your algae. Listing your test results, including CYA, will help.
    What types of chlorine have you been putting into your pool? Adding dichlor (a common shock) or trichlor (the common form of the 3" discs) could be counterproductive.
    18k plaster IG pool - cartridge filter - Pentair Superflo VS - Taylor K-2006
    Dolphin Nautilus Robotic pool cleaner
