Results 1 to 7 of 7
Thread: Blue Surf vs Blue Granite
    Mar 2016
    Spring, Texas
    69
    I'm a couple days away from getting the pebble sheen applied. I've selected Blue Surf but I'm wondering if Blue Granite is a better choice? I know this is all about personal preferences. The photos I've seen are so different depending on the angle of the shot, the sunlight, etc. blue surf is newer..so less photos are available. My PB says the blue surf has really taken over in popularity. Any opinions on these choices are welcome. Better yet, any photos taken with these option in full sun would be fantastic!! I'm going for a semi tropical look!
    THANK YOU!
    29x13x33, 18,000 gallon free form in-ground pool, 6-ton moss rock waterfall/weeping wall, blue surf pebble sheen, Pentair 520 cartidege filter, Pentair VSP, Pentair 2 HP pump for water feature, Polaris 280 cleaner, Rainbow 320 chlorinator, 2 skimmers, 2 colored LED lights, Auto fill, dual intermatic time clock w/freeze protect. 661 sq ft pea gravel decking with flagstone accents.
    Aug 2010
    Dallas, TX
    4,052
    Re: Blue Surf vs Blue Granite
    They could not give you samples?
    May 2015
    Land O Lakes, FL
    527
    We just did Blue Granite and love it. I would ask the builder for build that they have done of each and get a chance to go visit.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Mar 2016
    Spring, Texas
    69
    Quote Originally Posted by RobbieH View Post
    Yes, I have samples..but seeing those hasn't made the distinction clear.
    Quote Originally Posted by mgmoore7 View Post
    yes! I'll do this
    Jan 2015
    Austin, TX
    1,095
    I will say for me that Blue granite looks more greyish on the sun shelf while blue surf looks more sandy blue on the shelf. The finish color is blue on the blue surf but the pebbles are more tan so at an angle it looks somewhat tan.
    Here are some threads with the colors you want...
    I have blue surf with luminous beads added. There are shots of my pool on pages 37, 39, and 51 of my thread here:
    Yet another Texas pool build! - Page 37
    Marlahoutex also has the same finish as mine but with extra shells added. Her thread is here:
    I know there are a couple more with the blue surf without beads on here if you search.
    Sunbaby has blue granite on her thread here:
    New Pool Build - Conroe, TX - LOTS of pics! Come say hi Y'all.
    Suz also has blue granite on her thread:
    Another Pool Build in Cypress, TX
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    I have Blue Granite, and I like it. Blue Surf had just come out when I had to decide on the finish last July. I was tempted to go smurffy, but since there were NO pictures of pools with it anywhere (not even from PebbleTec), I chickened out. I think I would have been happy with it.
    My Blue Granite is definitely gray on the sun shelf and top 4-5 steps. I have to say, that doesn't bother me in the least. Again, the Blue Surf might have been prettier. As far as the rest of the pool goes, it surprises me how much green I see in the water. I was trying to avoid any greens. It's hard to say how the same finish will look in different settings. Even though we live in a neighborhood with average to small yards, there are still a lot of trees around us - pine and oaks. So maybe the greenish tints come from the trees. This really was one of the hardest decisions I ever made - so permanent. Ha! Even naming my boys was easier - if I didn't like the names, I could always use a nick name!
    If you have used colored waterline tile, go with what will blend nicely with it. I think that makes a big difference. If you used a neutral waterline tile, anything works!
    I did decide this - after about 6 months, I realized I spent waayyy too much energy worrying about the finish color!!! One thing for sure..... when I'm in the water, I could care less what color the finish is! For me, it's all about being IN the pool.
    Enjoy your pool!!!
    Suz
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Mar 2016
    Spring, Texas
    69
    Quote Originally Posted by ummgood View Post
    UmmGood! Thank you so much! This was exactly what I needed. Just seeing the photos on page 51 of your pool helps me a lot. Of course, I've looked and Sunbaby's Pool--she has a gorgeous pool with lots of great pictures. I've also checked out Suz's build in the past, again a very nice reference. The problem was finding good direct sun pics of the blue surf..all of the pictures I found were with cloudy skies and made me concerned that it was a bit dull. Based on my review, you really can't go wrong with either of these colors. I think I'll stick with the Blue Surf, as I think its a little lighter. Thanks again for all the time you took to point me to some good resources!
