Results 1 to 8 of 8
Thread: Cartridge Filter slows down flow too much
    Jun 2014
    Livonia/MI
    20
    I have an inground 6k fiberglass pool, with a Jandy 1 1/4 HP pump and Tropicflo cartridge filter. I'm needing to clean my filter weekly to keep the pressure from building. I was dumping some water and left the cartridge out and flow was amazing. I've had the same problem every year, with different brand cartridge replacements, We only have a 4 month pool season here in Michigan and I change them annually. Any ideas? Thanks
    Michigan- 6000 gallon inground fiberglass, 1 1/4 hp Jandy pump, Tropic flo 100 cart. filter, Hayward gas heater. Open Memorial day to Labor day.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: Cartridge Filter slows down flow too much
    How are you maintaining your pool? Pool$tore or TFPC?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2014
    Livonia/MI
    20
    All I buy from the pool store is liquid chlorine, I do have it professionally closed every winter.
    mas985's Avatar
    Pleasanton, CA
    11,741
    If you filter is clogging frequently, that usually mean you are fighting an algae bloom (and yes even if your pool looks "fine"). Have you tried an OCLT?
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    Mark
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    What are your current test numbers?
    What does it look like when you clean the filters? Hard crusty stuff or soft slimy stuff?
    Jul 2015
    Central Valley CA
    1,109
    I would definitely do the OCLT, additionally If you get a fair amount of visible debris a hairnet in the skimmer can cut down on the amount that gets to the filter a bit. The biggest befit is not having to empty the pump basket I only do that every couple of months if even that often.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    While a 100 sq ft cart filter works it is really small, I have 100 sq ft cart on my hot tub, it has 700 gallons
    A 320 sq ft would work way better for you but if you have algae it will still clog up, how are you testing your water?
    I hope this helps
    Jun 2014
    Livonia/MI
    20
    I have to Slam my pool every year I open it, extremely cloudy for about 2 weeks.
    The filter is mostly white cloudy water that comes out of it, very minimal slime or hard particles.
    I have a Taylor kit, FC & TC are equal.
