Thread: Air in Pipes
    Air in Pipes
    I know there is air in the pipes thus what makes the water circulate. My question is though is there such a thing as "too much air" in the pipes. When I first turn the pump on each day, the returns blow "hard" for a few minutes then they return to "normal", but I don't remember the returns ever blowing so much air out when I initially turn the pump on.
    Any advice? Thx.
    18x36 IG Vinyl Grecian Lazy L (20k gallons) ~ Whisperflo DS 2.0HP pump ~ QuadDE100 filter ~ Autopilot SWG DIG-60 ~ (7) 4x16 solar panels
    Re: Air in Pipes
    Is the water level in your pump strainer basket dropping when the pump is turned off? It is possible that you have a slight suction side leak somewhere. First place I would check is the o ring on the strainer basket lid.
