Thread: Polyquat 60 same as algaecide?
    Mar 2016
    Baton rouge, la
    9
    During an ascorbic acid testament it was recommended to use polyquat 60 while chlorine was low, is that the same as a store bought algaecide? If not where does one get polyquat 60?
    16 X 32 In ground vinyl liner pool. Approx. 15,300 gals.
    Pentair whisperflo 1.0 HP motor with sand filter. Test Kit TF100
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Re: Polyquat 60 same as algaecide?
    Polyquat is just a brand name. All the pool stores in my area carry a different brand. Look on the label, if it says 60% poly-ethylene it's the same as polyquat 60.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Mar 2016
    Baton rouge, la
    9
    Great thanks for your help
