Thread: Adhesive required when replacing key seal?
    Slartibartfast's Avatar
    May 2016
    Carp (Ottawa), Ontario
    6
    Hi, my Hayward filter is one of the ones where you can only buy the spider gasket already glued into the key seal. When replacing the gasket alone, you would normally use some kind of gasket goo. Before I go ahead and take it apart, will I be needing any adhesive or sealer, of just mount the new key seal assembly as is?
    Thanks again.
    This is the part in question: Hayward SPX0714CA Key, Seal Assembly Replacement for Hayward Multiport Valves and Sand Filter Systems: Amazon.ca: Patio, Lawn Garden
    20k Gallon Above ground, SWG - Hayward sand filter and pump.
    38,235
    Re: Adhesive required when replacing key seal?
    Pretty sure you just have to install the new assembly. No glue required.
