Thread: Old kooldeck flaking off - need suggestions
    May 2016
    macon ga
    20
    We have Kooldeck or a similar product on our patio. Not sure how old it is. It is constantly crumbling and flaking off. We also have some pretty significant cracks. We are trying to get the remainder of the kooldeck off. Any suggestions on what to replace it with and how to fix the crack?
    We did have a guy look at it and he suggested adding another joint where the major crack is. He said as big as it was the repair probably would not last. He could also grind off the kooldeck but it was too pricey for me.
    Thanks!
    21k vinyl IG grecian, hayward S244S sand filter, hayward power-flo LX 1.5 HP Pump, 10+ years? (came with house), taylor k-2006 test kit, aquabot optima cleaner
    Sep 2013
    Charleston, SC
    551
    Re: Old kooldeck flaking off - need suggestions
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,888
    If it is still actively crumbling/flaking, nothing will work on top of it. The loose material needs to all be removed before recoating with something. Cracks should probably opened up using a grinder and filled with a cement/grount-like material. Others can suggest specifically. Then it would be ready for your top coat. This could be another Kooldeck or similar.
    Or another possibility is this product called Cool! Concrete Coating. It's a kit with material that gets mixed with acrylic/latex paint and applied with a roller. The reviews are really good online and has been referenced here once or twice. It's quite expensive if you have a large area. But the warranty is impressive. I have no personal experience with it. I may try it on a small area some day as I will need to redo our stained concrete someday.
    http://www.amazon.com/Cool-Pool-Deck.../dp/B006I99IJQ
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2016
    macon ga
    20
    Thanks for the reply bmoreswim. We are trying to get all the old stuff off and that may take awhile because we have quite a large area covered in this.
    Apr 2013
    Sacramento, CA
    2,769
    Some pictures would be good showing the cracks close up and the whole deck. But the Kooldeck has to come off first. Depending on the situation you often get significantly better results jacking it up and re-pouring. But we need pictures to make that assessment.
