Thread: SLAM'ing...have a product question
    May 2016
    Fremont, NE
    2
    Hey all, first time opening for me and have a roundabout CYA question.
    We have a 20000 gallon SWG pool that I'm opening this week. After following what I've learned here, it's gone from Georgia swamp colored to a light haze.
    Up to now, we've been using bleach for the chlorine. However, I found a big bucket of Kem Tek All-In-One Granules leftover from last year in the shed. Our CYA level is currently sitting at 30, so it needs to be raised significantly anyway.
    I'm GUESSING we could use the entire bucket of that stuff and not make much of a dent in the CYA level? However, it's much easier to ask the experts than fix the consequences of my ignorance. We do have some real CYA on standby to bring it up to the appropriate level.
    Just want to say that this site is incredible. It's saved us a ton of money and heartache over the last couple of years. Thanks in advance!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: SLAM'ing...have a product question
    It looks like it's dichlor so if you want to use it, select that in the Effects of adding Chemicals part of Pool Math and see what it will do to you.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    TFP is all about putting into your pool what it needs. As long as you understand what you're putting in your pool, go ahead and use it. Just be careful that you have a good estimate of your pool volume and know how much you're going to use up to what point with your CYA. I wouldn't go over 40 or 50 ppm CYA.
    Thanks for making that first post and welcome to TFP!
    Isolated Spa - 345 Gallons
    May 2016
    Fremont, NE
    2
    Quote Originally Posted by pabeader View Post
    Thanks for pointing that out! Been on that thing a hundred times and didn't scroll down far enough. It's exactly what I needed.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Don't feel bad. It's missed by many. Very handy for sure. Be sure you have your pool volume set properly.
