Thread: Pentair Intellibrite LED Pool Lights
    Shekkie's Avatar
    Jul 2015
    Grafton, Ohio
    68
    Previously my pool had 2 Pentair 250w Aqualights which had seen better days so I replaced them with the LED Intellibrite lights (100w equivalent). The Aqualights are "spa sized" so I didn't have a ton of options.
    One of the Aqualights is all that worked since we bought the house last year and it seemed to do an adequate job of lighting it's section of the pool....not great but OK. I was a bit concerned with the LED lights since they are about the same as a 100w conventional light (now 200w vs. previous 500w) but most reviews led me to believe they'd work out. After properly sorting the light install and various other electrical issues I finally was able to check 'em out in action......
    I couldn't be happier. A nice glow but not too bright and good coverage with no dark areas (the pics make it look a bit darker than reality). Exactly what I was hoping for.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pentair Intellibrite LED Pool Lights
    That looks very nice I like that it also lit the stairs up
