Results 1 to 11 of 11
Thread: ZeoSand and Aqualoon
    Apr 2009
    SC
    26
    Hi all,
    I'm about to go through the tedious process of changing filter sand in my 300 lb. sand filter. Anybody with experience with ZeoSand? You thoughts, experiences would be helpful. Also just got a circular from Doheny's with a new product called Aqualoon. Anyone with any experience with this product? Thanks for all the feedback
    43,500 gal/Heyward 240 sand filter w/ 1hp pump/In-Ground pool/vinyl liner/Jandy SWG
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: ZeoSand and Aqualoon
    Is there aReason you want to change the sand? Generally, a deep clean is all that is needed. Therea re mixed reviews about the Zeosand.
    Deep Cleaning a Sand Filter
    Apr 2009
    SC
    26
    I have SLAMMED my pool (it was a swamp green prior to this) and it has remained cloudy after 2 weeks of filtering. My only guess is that the sand grains have started filtering less as the sand was changed 3 years ago. My current numbers (currently doing another SLAM to try to get rid of the cloudiness):
    FC 15
    pH 7.2
    CYA 40
    TA 80
    Also, I read the article on "Deep Cleaning a Sand Filter" and have done this after the first SLAM. I was amazed at the truly foul smelling gunk that came out. After 2 hrs of washing the sand, the effluent was clear. At the recommendation of a friend, I put a gallon of Clorox in the sand an allowed it to sit for 24 hrs before re-starting the pump. The water is cloudy still.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I would definitely try the deep clean if I were you.....
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    482
    You changed the sand 3 years ago, so that is not the problem. If your water hasn't cleared up, you didn't complete the SLAM. Remember you need to meet all 3 criteria to complete it. Keep it up!
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I missed the bottom part if your post, lol.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Return the Zeosand and do this, if your FC is staying up and your CC is < .5
    Pool School - Add DE to a Sand Filter
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Apr 2009
    SC
    26
    Thanks to all. RazorHog - have done the second SLAM for 5 days now and the FC has remained stable by the Overnight FC Drop Test and all criteria met. PABender - sorry I left out that I have tried adding DE to my sand filter, but no matter how little I use, the pressure goes up after 24 hrs and I have to backwash it out with no obvious change in pool clarity (have done this 3 times thus far). How long should I give the sand filter to clear the cloudiness? Also, any thoughts on flocs vs. coagulants?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    The pressure going up is a good thing. Most folks don't get 24 hours before they have to backwash it and do again. So far everything you are telling us, points to the same thing. Still have a bit more to do.
    Apr 2009
    SC
    26
    Thanks to all!! I'll keep plugging along
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by bigdog12 View Post
