Thread: IC60 needs separate power supply? EasyTouch already installed
    Aug 2010
    San Diego
    18
    I installed an EasyTouch, intelliflow and intellichlor IC40 about 6 years ago. My IC40 failed at the end of last season and I decided to step up to an IC60.
    The manual for the IC60 says that I need a separate power supply.
    "CAUTION - The CIC60 or the CIC60S can onlybe plugged into a PC100 or CPC100 power center. Do not plug into intelliTouch, EasyTouch or SunTouchsystem."
    Can anyone tell me why?
    I don't want to drop another $3-400...
    Thanks for the info.
    27,000 gal 615sq/ft surface area jacuzzi attached
    FNS Plus pentair 48sq/ft DE
    In ground plaster
    Intelliflo vs, EasyTouch and Intellichlor
    38,301
    Re: IC60 needs separate power supply? EasyTouch already installed
    I can only assume that it needs more power that the Easytouch has available.
    The CIC60 is the commercial version. The regular IC 60 might be ok with easytouch. Check with Pentair to be sure.
    Do you have a separate power center or one integrated into the Easytouch?
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    According to the Intellichlor manual the IC 20, 40 and 60 all use the same power center. Agree that a call to Pentair to confirm is a good idea.
    Manual here, http://www.pentairpool.com/products/...nerator-75.htm
    JoyfulNoise's Avatar
    May 2015
    13,213
    JamesW is correct, the CIC is the commercial unit and it requires a different power supply. The transformer built into your ET panel is rated for the IC20, IC40 or IC60.
    Matt
    Aug 2010
    San Diego
    18
    James and Joy hit this one on the nose.
    I was shipped a CIC60S P.N. 521005 not the IC60 P.N. 5211105 that i ordered.
    The CIC units are designed to be part of a manifold of 9 chlorinators for commercial application. 1 CIC60 and 7 CIC60S units make the maifold, each one has its own seperate powersupply. The CIC60S is a secondary (slave) unit to the CIC60 and they do not have interchangeable power supplies. http://pentaircommercial.com/datastaging/pdfs/intellichlorcommDS.pdf
    I have contacted the supplier and they are working on a resolution. They answered the phone right away and assured me they would take care of it. And they had the best price on the web.
    In ground plaster
