Results 1 to 8 of 8
Thread: SLAM Question
    james63038's Avatar
    May 2014
    St. Louis, MO
    35
    SLAM Question
    When I opened my pool, the water was clear. During the 5 days that the cover was off, I threw some bags of shock in there (leftover from last year) and added some bleach as instructed on here daily until the pool company came to show me how to start everything up. That being said, do I still SLAM if the water is somewhat clear? I tested tonight just the FC (4) and CYA (30) but am curious if I need to bring the FC up to shock level at 12.
    My Build 20x40 Freeform Shotcrete (33k gal) pool. 3.6-8.6, Blue Granite Pebble Sheen, Tennessee Flagstone Coping, Sta-Rite System 3 Modular Media Cartridge Filter, Intelliflo 4x160 x SVRS, Rainbow Automatic Chlorinator, 1 LED light, Tanning Shelf, 15.6 Slide with 3 different height jumping rocks, Sta-Rite 333k btu propane heater, kool deck, TF100, Dolphin Oasis Z5
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: SLAM Question
    Quote Originally Posted by james63038 View Post
    The best way to tell if there's something growing in your pool is with an Overnight Chlorine Loss Test. Unless you can see algae or feel the sliminess on the walls, then you know you have algae. If you fail the OCLT, you need to SLAM. 30 CYA is perfect for that.
    james63038's Avatar
    May 2014
    St. Louis, MO
    35
    Re: SLAM Question
    Great, thanks! I'll test first thing in the morning.
    james63038's Avatar
    May 2014
    St. Louis, MO
    35
    Re: SLAM Question
    The FC went down to 3. Do not SLAM?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: SLAM Question
    Have you measured the CC as well? As long as your water is clear, your FC loss was 1 or less and your CC is 0.5 or less, then no need to SLAM.
    Isolated Spa - 345 Gallons
    james63038's Avatar
    May 2014
    St. Louis, MO
    35
    Re: SLAM Question
    No I didn't do that last night but I will. Thanks!
    james63038's Avatar
    May 2014
    St. Louis, MO
    35
    Re: SLAM Question
    No CC's so I guess I'm good. No SLAM.
    Feb 2014
    Central Minnesota
    5,080
    Re: SLAM Question
    Looks good! Glad your trouble free.
