Thread: Waterfall and deck jets working on the same pump
    May 2016
    Bloomington/IL
    3
    Our installer put in a waterfall that recirculates pool water and 4 deck jets on two valves but one pump. We are able to run either the deck jets with the waterfall or the deck jets without the waterfall. We would like to run the waterfall without the deck jets but the installer states they only installed one pump so that cannot be done. Is there anyway to fix this so we can run the waterfall without the deck jets?
    38,524
    Re: Waterfall and deck jets working on the same pump
    Welcome to TFP!!!
    Please post a picture of your plumbing setup. Should either be possible already or a simple plumbing change.
    May 2016
    Bloomington/IL
    3
    I don't know where the plumbing set up is located. Is there a certain place I should look, do you know?
    May 2016
    Bloomington/IL
    3
    We had a waterfall built leading up to the pool and leading to the lower waterfall that recirculates the pool water. Are we incorrect in thinking that it would be common sense to have the lower waterfall and the deck jets on seperate pumps?
    Aug 2014
    NJ
    435
    The plumbing set up is where all the pumps and filter are. He wants to see a picture of the pipes attached to those pumps so he can see how the water is flowing from your equipment pad to the pool. From the way you described it I am guessing that from your equipment pad water goes to a pipe that flows through to the deck jets. But it sounds like there is another pipe attached to that pipe that permits some of the water that would otherwise go to the deck jets to be diverted to the waterfall. We need to see the pictures but it sounds like they can add another pipe that would divert the water going to the deck jets back into your returns in the pool. That way the waterfall would get water and the deck jets would get none.
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
