Results 1 to 9 of 9
Thread: Kichler hardscape lights or alternative?
    Oct 2015
    DFW, TX
    176
    I assume Kichler is the big player if we're wanting to add some lighting on our retaining/seating walls around the pool decking and fire pit but was wondering if anyone had any experience with some of the other (cheaper) options like VOLT and G-LUX?
    Sep 2013
    Charleston, SC
    537
    Re: Kichler hardscape lights or alternative?
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Mar 2016
    Huntington Beach CA
    145
    I would like to know this also? Thinking about adding some lights around the fire pit like these... Stainless Steel Paver Wall Light - LED Bronze - Landscape Spotlights - Amazon.com
    K8Luvs2Run's Avatar
    May 2016
    McKinney, TX
    17
    We had Vista landscape lighting installed in our yard 8 years ago and only last month when I had a issue with one light did I find out they weren't Kitchler! These lights have been rock solid!
    Oct 2015
    DFW, TX
    176
    bump. anyone else?
    We used Lightcraft.
    http://www.lightcraftoutdoor.com/upl...ft-2015-LR.pdf
    Search for "new build in south Texas" thread for night pictures
    I think one of the main differences is the quality of the connector supplied between the fixture wire tail and the main power wire you lay out from the fixtures to the transformer. If you get cheaper fixtures, this connector will not be water tight, and will eventually corrode and fail. For my cheaper fixtures I'm cutting the connector off and using direct bury rated (silicone filed) wire nuts, available at your local sprinkler store. I use the factory connector to lay the lights out and make sure I like there positioning and then go back and cut the wire and splice it back together with the wire nuts after I'm happy with everything.
    8.5k gallon IG pebble sheen play pool with Intellitouch control, Intellifo VF, IC 20, Rainbow tab feeder (not currently in use), Pentaire mystery cartridge filter with labels faded to the point I have no idea on the model, Intellibrite 5g LED light, Hayward Navigator. Adding IntelliPh and Crestron control next.
    Oct 2015
    DFW, TX
    176
    VOLT appears to get pretty good reviews are about 60% of the price of the Kilchers. I may go that route.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    I got a 72 foot string of solar Christmas tree lights from Amazon for $18. They turn on automatically when it gets dark enough and give great ambient lighting. We got a white light "stick in the ground" style at the bottom of the stairs, but that's about it. The tiki torches are for when we want more light.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
