Results 1 to 13 of 13
Thread: Adding chemicals with dead pump
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Hey all,
    So my pump motor is fried. A new one is being delivered in about 6 days. In the meantime my pool looks like the swamp thing is going to crawl out of it any moment.
    My biggest issue now is the party Im having for memorial day. Ill still have a little over a week to get it sparkling blue after the pump is installed. But letting it sit there like this is killing me a little more each day
    Can I bring the pool to shock levels and agitate the water with a brush? Is that safe? I won't be on top of it as much as I would be if the filter was running. But I can at least get the process started and keep adding bleach.
    Or would it be smarter and safer to just suck it up and wait the 6 days? Thanks!!!
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    38,267
    Re: Adding chemicals with dead pump
    You can certainly add bleach and brush a lot ... your test results will be questionable since the water will not be well mixed.
    May 2016
    Clermont, Florida
    27
    Especially with a vinyl liner , you dont want to put any chemicals in without the pump running.
    You're better off waiting to fix the pump. Not much you can do right now.
    The de filter and keeping the system running will bring your pool around fast. Especially with the help of TFP.
    Good luck
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    That's 2 very different opinions Eenie Meanie?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Pick up a cheap submersible pump and use it move the water around. Harbor Freight has cheap ones.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2016
    Clermont, Florida
    27
    If you do not know your water chemistry, it can do no good to add chemicals. Your liner is vinyl and the pros do not outweigh the cons. I would wait ,personally.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Thanks everyone. I think I will wait it out. Maybe try to convince them to install the pump a little sooner.
    On a positive note, American Home Shield is replacing the dual speed pump. That kind of rocks...
    Jun 2014
    15,059
    Hummmm. Gotta remember that one. They're still trying to get me to join.
    May 2016
    Freehold
    27
    Would never buy one of those warranties again. I bought one and they then said that i didn't service annually with qualified technician as reccomended by the provider and therefore they canned warranty.. I fought via credit card and won my $ back... They will only fix little things, unless you are paying through the nose for annual maintenance on your hvac and a/c units and pumps and water heaters, they won't pay a dime to fix... be careful....
    Freehold, NJ 22x44 36k gal gunite , SALT system Nature 2 Fusion Soft (NO mineral cartridge), Jandy LXi gas heater, Jandy DEV60 DE filter, 2HP pump, Jandy LED lights (GARBAGE little use in 3 years BROKEN), Polaris 280 pool vac, Meyco mesh (too windy for solid), separate hot tub--Grandee Vista by Hot Springs w/ ACE salt system! Wish I never bought a pool most days but some days, I do finally relax! I do appreciate the help! K2006 & strips
    Nectarologist's Avatar
    Apr 2015
    New York
    427
    mitch do what pabeader suggests. Take the submersible pump and just have the hose empty back into the pool. You can add chemicals and it will save a lot a aggravation especially if you want to swim at the party. If its already a swap another week of sitting and it won't be ready in a week for the party. Granted the submersible pump won't move water like the pool pump but if you run it 24/7 it's a lot better than letting it sit.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,983
    I wouldn't attempt to adjust pH or SLAM without good circulation, but you can certainly add some bleach to keep things from getting worse. A jug or a jug and a half every day, followed immediately by a good brushing. Or a submersible pump. You don't have a robot cleaner do you? That'd keep things stirred up.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sometimes you just have to get creative, here is a thread I posted when I was in a similar situation a few years ago Keeping the water moving
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    I have heard many negatives and positives from people. But I can only talk about my own experiences.
    Ive had the warranty company for 10 months. in that time they rebuilt my heating furnace ($1200 job) and are replacing this dual speed motor and pump (over $600).... Those are the only 2 things Ive called them about.
    So, so far Ive been extremely happy with them.
    Thanks a million for the advice everyone!!! You guys rock as usual. The pump is being replaced tomorrow morning so the shock process starts tomorrow afternoon
    Cant wait to get this swamp back to normal.
