Thread: Sand shooting thru return jet.
    May 2016
    Marshfield WI
    12
    Question Sand shooting thru return jet.
    I just bought a house with a pool last fall, and now I'm finishing up slamming the pool because it was green. Its been a week and the water is looking clear although it is still a little cloudy. I shut off my pump to rinse out the pump's skimmer basket and when I turned the pump back on, the jet shot out a brown cloud. I found out that it shoots out this brown cloud every time I shut the pump off and then turn it back on. I caught some of the brown cloud in a sock and found out that it is my filter sand.
    Some background, last fall when I closed the pool I found out that the PVC pipe in the sand filter was broken and all of the sand was gone. I replaced the PVC pipe and put brand new sand in the filter.
    Some ideas I have are: A bad lateral or I didn't install the new PVC pipe correctly. Is there any chance the multi-valve could be the problem? I'm debating between replacing the laterals or replacing the entire multi-valve assembly.
    Any thoughts on what to do to fix this?
    14600 gallon above viynl ground pool, sand filter, and Zodiac Clearwater SWG.
    Aug 2010
    Dallas, TX
    4,052
    Re: Sand shooting thru return jet.
    Bad lateral or laterals or other elements not fully connected, or broken manifold are the likely issues. I am pretty sure a bad valve won't do it.
    May 2016
    Marshfield WI
    12
    Sorry, but I'm new to pool ownership. What part is the manifold?
    Jun 2014
    15,008
    In this pic you see the vertical standpipe that goes down to the manifold assembly where the laterals (fingers) are attached.
    May 2016
    Marshfield WI
    12
    I bought a new manifold and lateral assembly and replaced the old one. I think the probably was that I wasn't back washing and rinsing the filter when it got air in it. I found out that when I vacuumed the pump didn't stay completely full with water and some air got in it. When I pulled the vacuum off some of the dirty water in the filter got blown back into the pool while the pump got a blast of new water. If I turn the pump off before I pull the vacuum off, then backwash and rinse, no dirty water gets sent into the pool when I turn the pump back on.
