Thread: A Lesson Learned
    viking68's Avatar
    Lake Mary, FL
    69
    A Lesson Learned
    I've been "living" with my TF-100 for a few weeks now. Today, I learned to "pay attention".
    Saturday, 5/7:
    TC: 7.0
    pH: 7.5
    TA: 90
    CH: 300
    CYA: 35
    This morning, 5/12:
    CL: 4.5
    pH: 7.6
    TA: 80
    CH: Did not test
    CYA: 35
    Added some stuff - see below.
    This evening:
    CL: 9.5
    CC: 0
    pH: 7.2-
    TA: 70
    CH: 350 (ran twice - how did this go up?)
    CYA: still 35. Probably don't need to test this so much.
    So after a test (above) and brush (this morning), I "felt" the chlorine should be a little higher, so I dumped in about a gallon.
    More is better, right? Before TFP, this probably would have been "about" right. Dummy. Use PoolMath. I wanted Cl to hit about 5 - 5.5. PoolMath tells me I should have added 2 cups (16oz), so I added 8 TIMES MORE THAN I NEEDED!
    Acid - same thing. I'm worried about algae, so, more is better, again - 1/2 gallon or so. PoolMath tells me I should have added about 2 cups (16oz), (to get to 7.3) again, added about 4 TIMES MORE THAN I NEEDED!
    Lesson learned - USE POOLMATH!!! I've got this pool so well balanced, it takes "just a little bit" compared to the old Pool Store Days!!!
    I'm putting in 16 oz of stablizer and then will test on Sunday.
    LESSON LEARNED! Just like a guy (the girls will say) - doesn't follow directions.
    I am SO GLAD I'm here and have learned all this - wife says the pool water is great (well, not so much today, but nobody was swimming). Hit it with a .lb of baking soda in a bit (PoolMath!)!!!
    I simply cannot believe how "little" chemicals are needed when you get the water balanced.
    20K gal, IG Free-Form Plaster (1986), 1 HP Pentair Superflo pump, PAC FAB FNS-36 DE Filter, Polaris 280, Screened, Cool Deck.
    Solar Heater
    TF-100 Test Kit
    Jun 2014
    15,067
    Re: A Lesson Learned
    Yep, that calculator is a life-saver. It's great you're getting the hang of it.
    38,271
    Just a note: I am not sure why you are equating the pH to getting algae ... perhaps you are thinking of the belief that the chlorine is less effective at high pH? Well, that is not true when there is CYA in the water.
    To avoid algae, focus on the FC and it ratio with CYA
    OH, and baking soda is not the right chemical to use to bump up the pH ... you need borax or soda ash.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Yep, it really is just that easy. In time, you'll learn your pool so well that you'll predict the readings with amazing accuracy before drop one leaves the bottle. You'll also know pretty much how much of what to add without having to refer to poolmath.
    During Summer, I use a quart of 12.5% bleach every day and about a quart of acid weekly, and that's it. My test kit has paid for itself many times over.
    viking68's Avatar
    Lake Mary, FL
    69
    Really? Once again, I "knew" baking soda was the answer. See? Here all my TFP pals saved me once again! I actually got a box of borax earlier this week because I "remembered" reading it was one of our required chemicals!
    Thanks, y'all!
    Solar Heater
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
