Results 1 to 11 of 11
Thread: Intex saltwater system won't turn on/GFI switch will not reset
    Apr 2016
    Hutto, TX
    6
    I have an Intex Saltwater System that I bought two years ago and went to startup the pool for the first time this year and got absolutely nothing. No lights whatsoever and the GFI switch will not reset. No clicks when pushing rest or reset button. Does anyone know if there is an easy solution for this?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Re: Intex saltwater system won't turn on/GFI switch will not reset
    Is there power to the GFCI? The will not reset if the power is off.
    Support the site
    Apr 2016
    Hutto, TX
    6
    Yes
    Jun 2015
    langhorne/pa
    4
    You say there's power to the gfi outlet. Can you plug another device into it, and have it work?
    My experience is it's either no power to the gfi, or the switch is defective and needs to be replaced.
    18 X 36 rectangular pool (vinyl).
    Average depth of 6'
    Approximate volume of 29100 gal.
    Circupool 60 SWG installed April 2016
    1.5 hp pentair pump sand filter
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Is it the GFCI on the cord? My husband had to replace the end of the cord last year due to the same problem. He had installed a GFCI outlet for the pump, so he put a regular plug on it. (Was lucky to have married an electrician, lol.)
    Apr 2016
    Hutto, TX
    6
    Yes, the one on the cord. I did not think it was a good idea for my husband to try to splice a chord that will be near water. Just didn't sound safe to me
    Jul 2014
    Hope Mills, NC
    566
    GFCI's can and do fail.
    A simple replacement might be all that you need. Better to change the outlet to a GFCI and change the cord to a standard cord. You will be just as protected.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Apr 2016
    Hutto, TX
    6
    I needed a quick solution so I just bought a new unit. Changing the outlet sounds like a good long term solution though. I'll have to see if I know anyone capable!
    Jul 2014
    Hope Mills, NC
    566
    YOU are capable...Shut off the breaker, pull the current one out, look at where the wires go and replace it with the new one...no problems. It will save you $100 for an electrician. Should only take 5 minutes.
    Its one of the most basic home owner skills, just like changing a deadbolt on your front door or un-plugging a toilet with a plunger.
    Vinyl in-ground
    1 HP Pump
    Hayward SWG
    Apr 2016
    Hutto, TX
    6
    Didn't realize it was that easy! Thanks!
    Jun 2016
    St Michaels, MD
    1
    Quote Originally Posted by egotrip View Post
    egotrip: My saltwater system stopped working (light no longer comes on). I believe my problem must be the on/off switch, which has always seemed shaky (had to wiggle it to make it work). Do you know where I could find this specific switch for replacement. Thanks!
