Results 1 to 13 of 13
Thread: Ready to add salt
    Nov 2015
    Boston, MA
    120
    Ready to add salt
    Weather is warming up and ready to move away from bleach everyday and get the swg going. 30k gallons and never added salt before. Any best practices for first time salt user? Figured id add 500 lbs tonight and turn on swg tomorrow? Pool math called for about 750lbs. Water is balanced bit ill have to get cya up as its at 50.
    18x44 double Roman vinyl pool, Hayward superpump, Hayward DE Filter,
    Aqua Rite T15 SWG, Taylor k 2006 test kit
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Re: Ready to add salt
    Brush, Brush, Brush!!!!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Aug 2010
    Dallas, TX
    4,052
    Turn off the SWG. Add salt to shallow end. Wait until salt is completely dissolved before turning on SWG. It can take 24-48 hours, but it usually goes faster for me.
    Nov 2015
    Boston, MA
    120
    Run pump all night? Can the salt dit on bottom? Ive brushed for a long time
    Aug 2010
    Dallas, TX
    4,052
    salt can sit on bottom, won't hurt a thing.
    Nov 2015
    Boston, MA
    120
    Added 14 40lb bags last night around 7pm for first time ever salt start up. Ran pump through the night and checked with Aqua check test strips at 8am and it said only 500 ppm. The reading on chlorinator said 2900ppm. Pool math originally said 752 lbs.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Test it tomorrow.
    Are you manually adding liquid chlorine?
    Aug 2010
    Dallas, TX
    4,052
    Be sure you use the test strips correctly. Put it in 1" of water and let it sit until the little strip at the top turns from yellow to black.
    I haven't had good luck with the strips, but the main thing is, if the SWG is happy, everyone is happy.
    Nov 2015
    Boston, MA
    120
    I had it submerged completely under water. Ill retry later. I think the swg has to be on for 24rs to get the proper reading. I was adding chlorine manually but i didnt do it last night or today.
    Nov 2015
    Boston, MA
    120
    Currently at 3100 ppm of salt! 15 bags. Just gotta dial in the % dial now. I went in the water tonight at 67degrees. It was awesome!!!!
    Captain 776's Avatar
    May 2016
    Thailand
    163
    Here is what I do when I add salt.
    I appreciate feedback from more experienced "Poolies" on my process.
    First thing, shut SWG OFF.
    Put multiport on Recirculate
    Scoop the salt from the bag and sprinkle slowly into the water flow from return jets.
    it seems to dissolve quickly this way.
    After adding a 100 lb bag, put the brush on and agitate the entire bottom as best you can.
    12-24 hrs later, I put multiport in Filter and turn SWG BACK ON.
    THE so called self proclaimed "EXPERT" that built my pool showed me how to jam a 100 pound bag down the skimmer. At first I didn't know better myself.
    Then I read all I could find on the net about having a salt water pool.........EVERYTHING, I read said, NEVER PUT SALT DIRECTLY INTO SKIMMER.
    After a few months, I removed my SWG cell. Ohhhhhhh my god, just about completely blocked across the plates. At this time, the SWG was only 4 months old.
    I wish I had a picture.
    I soaked it for an hour in a 20% muriatic solution, it looked like brand new.
    I just took it out to inspect it 6 weeks ago, still completely clear, no scaling or build up.
    NEVER add salt directly into skimmer.
    Captain
    8M x 4M X 2M no slope IG CONCRETE w/ceramic glass tile
    17,000 Gal EMAUX SWG JAZZI FILTER W/1-3 mm glass media, Jazzi Multi-port valve with
    T-750 filter w/ glass media
    1 main drain sump -3 returns - 1 skimmer
    Kokido digital salinity tester, Kokida drops for CL Hanna digital PH meter, Taylor K-2006
    Nov 2015
    Boston, MA
    120
    Nov 2015
    Boston, MA
    120
    Clearly i cant get a link to post a picture!!
    http://
