Results 1 to 10 of 10
Thread: AO Smith Motor Is Humming and Wont Start
    Apr 2016
    mass
    6
    Hi All,
    I have a Starite pump with an AO smith Motor C48K2PA105C5 1 hp. I tried to get it going and it just hums. I figure it rusted up over the winter and I could not reach the impeller to move it along. Does anyone have any tricks to try and save the motor?
    Thank you in advance for the help
    Jun 2014
    15,189
    Re: AO Smith Motor Is Humming and Wont Start
    With power disconnected, see if you can get to the back and turn the motor from there to break it free. You might have a cover in the way, but then might be able to get a wrench or socket on the motor's shaft to spin it a few times.
    Yuma AZ
    71
    Can you access the rear of your motor and attempt to spin motor shaft with a 1/2 wrench? This will help identify if your motor is truly seized. Next check your capacitor located on top of motor. Do a thread search for "motor humming"
    Someone will be along to give you more information soon.
    Apr 2016
    mass
    6
    I was hoping it had access to the shaft but its blocked. Can I remove the contacts to get at it?
    Jun 2014
    15,189
    mas985's Avatar
    Pleasanton, CA
    11,741
    Just try to turn the governor (silver piece with the springs). It is attached to the motor shaft.
    Mark
    Jun 2014
    15,189
    lilhall, any luck getting to that motor shaft? Are you able to salvage that motor?
    Apr 2016
    mass
    6
    Hi All,
    Thank you for the help, I was worried that I was going to break the spring but your suggestions worked. The pump motor is back in service.
    mas985's Avatar
    Pleasanton, CA
    11,741
    That usually means the bearings are starting to go so you might want to prepare yourself for a motor change at some point.
    Mark
    Jun 2014
    15,189
    Good to hear you are operational again.
