Thread: New to me 24' x 54" AGP, can you identify manufacture or answer question about stabil
    May 2016
    Bethany, Oklahoma
    2
    <br />
    I dismantled the pool, originally it had bead receiver coping only ( no stabilizer rail) and a bead in liner.<br />
    My goal is to add a deep end when I build the pool. After talking to my local pool store I've found I'll need to use a overlap expandable liner. <br />
    My question is does this particular pool require a stabilizer rail on top?<br />
    I know I'll have to buy the vinyl coping for a overlap liner. The large top resin rails do have a groove that overlaps the pool wall by apx. 11/4&quot; does this possibly take the place of the stabilizer railing? <br />
    <br />
    Sent from my SM-N910T using Tapatalk
    May 2016
    Bethany, Oklahoma
    2
    Re: New to me 24' x 54" AGP, can you identify manufacture or answer question about st
    Bump
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP from OK
    I wish I knew, I was hoping someone would be able to answer your question... most buy and use the pool the way it comes from the manufacture so not many people modify them there are a few, just not many..
    It may be a while before someone comes along that will know ..
    Casey's Avatar
    SW PA
    10,448
    If you're going with an overlap liner it will need a stabilizer bar over the coping strips.
