Thread: My name is Kimberly From KY.
    May 2016
    irvine, ky
    2
    I am looking for some help. we are converting a concrete pool to put a vinly liner in it and i need help finding this part. It is a High density foam insert for the corners of the pool to make it go from a 90 degree angle in the corner to a 6 inch radius
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: My name is Kimberly From KY.
    Welcome!
    Sorry no one has answered you yet. Maybe this will help.
    I have zero experience with this, but I do know the part you want is called Pool Cove. That will give you something to google.
    Mar 2015
    US
    122
    This may be it (no picture on the site):
    6 inch Radius Foam Corner Filler
    Or this is not exactly what you describe, but might work:
    Upright Corners
    29,000 gallon vinyl liner custom designed lagoon style in-ground pool (self-built 2015-2016), Hayward EcoStar VS pump, Hayward HP21404T Heat Pump (140K BTU), Hayward Pro Grid DE DE6020 Filter with Fiber Clear, Hayward Tiger Shark, 2 Hayward Color-Logic LED lights, Stenner 45MPHP10
    370 gallon Jacuzzi J-345 spa with ClearRay UV
    Casey's Avatar
    SW PA
    10,423
    Welcome to TFP!
    22,542
    If all you need is a 6" radius, you could use some foam cove. It'll conform to a radius once the liner and water is pressing on it.
    Welcome
