Thread: LaMotte ColorQ PRO 7
    samwestx's Avatar
    May 2016
    Weslaco, Texas (DEEP SOUTH TEXAS)
    99
    is this better than the TFT water tester?
    15000 gallon pool (15x30 + 7x7 sitting area), IG-Blue Pebble, Sand Filter-Hayward Pro Series, Pump-Hayward Tristar VS pump, Water Test Kit-TF 100, NEW POOL-COMPLETED ON 5/7/16, City Water w/no restriction, Dolphin M400
    Aug 2010
    Dallas, TX
    4,052
    Re: LaMotte ColorQ PRO 7
    No.
    I guess you want the long answer though, right?
    38,262
    I agree with Robbie, for a number of reasons that are discussed in many threads that you should be able to find with the search function
    samwestx's Avatar
    May 2016
    99
    i will take your word for it......
    38,262
    We generally do not trust any of the digital testers. Never know if properly calibrated or if just giving false data.
    On top of that, this one has the limitation of the FC only going up to 10ppm, which is not enough if you have an algae problem.
