Thread: Pump Leak at rear shaft w/pic
    Aug 2011
    Central Florida
    87
    In addition to dealing with high CH levels, this morning I noticed moisture under my Polaris booster pump. Below is a picture of the leaking area. I know it is sideways but it shows up a lot better. Is this a relatively easy tear down? What parts do I need for this?
    My locally owned pool store doesn't charge for labor, but it is built in to the part markup. Is this something I should just take out and bring up there?
    19K gallon rectangular, uncovered. Polaris 280 Hayward DE3620 Filter. Taylor k2006
    38,248
    Re: Pump Leak at rear shaft w/pic
    That is a leaking shaft seal. Fairly simple fix.
    If you are going to have the store do it, just give them the entire motor/pump.
