Results 1 to 19 of 19
Thread: cloudy water not clearing during slam
    May 2016
    macon ga
    20
    Hello all. Newbie here. We are on our 3rd week of the slam and my water has gotten blue but it is not clearing. We do have a sand filter and I know that they are slower to clear. The water hasn't really changed any since Monday. I take a pic every afternoon to compare. Filter running 24/7 backwashing when it increases 25%. Scrub twice a day. Checking levels 4-6 times per day.
    ph was 7.4 when we started. I haven't rechecked
    TA 100
    CYA 40
    FC 15 (added 2 c bleach to reach 16)
    We were gone for a couple of days last week and used pucks in the skimmer. They were removed when we returned and slam started again after rechecking our CYA.
    Just wanted to make sure we weren't missing something.
    21k vinyl IG grecian, hayward S244S sand filter, hayward power-flo LX 1.5 HP Pump, 10+ years? (came with house), taylor k-2006 test kit, aquabot optima cleaner
    Aug 2010
    Dallas, TX
    4,052
    Re: cloudy water not clearing during slam
    Have you tried an OCLT to see where you are?
    38,540
    Have you Deep Cleaned your Sand Filter ever?
    If you are passing the OCLT and have checked/cleaned the sand, you could try to Add DE to your Sand Filter
    May 2016
    macon ga
    20
    Thanks for the quick response. I will try the OCLT tonight. I'll have to set remember to set my clock. We did clean the sand before we started slamming. We haven't been able to find DE in our area. We did find cellulose fiber. Will that work?
    Aug 2010
    Dallas, TX
    4,052
    If you have to backwash a lot already, it will increase the backwash frequency so that you'll be backwashing even more. And, each time you backwash, you'll have to re-add the DE. Depends on if you are OK with that or not.
    May 2016
    macon ga
    20
    We were backwashing a lot at the beginning of the slam. But there hasn't been an increase in pressure all week. Should i backwash anyway?
    Aug 2010
    Dallas, TX
    4,052
    Nope, backwashing before necessary only decreases the filtering efficiency.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Quote Originally Posted by mambawamba View Post
    The cellulose fiber will work but I question the lack of DE. Lowes and Home Depot both carry it in their pool areas. Any pool $tore will carry it, also. Just be sure you by the pool DE, not the garden DE.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2016
    macon ga
    20
    Thanks I will check with them.
    May 2016
    macon ga
    20
    Passed the OCLT, 14 last night 13 this morning. Adding fiber today to filter today. From what I've read on here, the procedure is the same as adding DE to the sand filter.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    yep, use the same way.. add till your pressure raises 1 PSI and then watch the magic happen
    May 2016
    macon ga
    20
    Abracadabra
    May 2016
    macon ga
    20
    3rd day of using fiber and still not noticing any clearing. Any other suggestions?
    May 2016
    macon ga
    20
    Day 4 on the fiber and i still can't see the pattern in the pattern in the shallow end. Any other suggestions?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Maybe fiber doesn't work the same as DE? Could you post your daily pics?
    May 2016
    macon ga
    20
    I just realized I forgot to take one yesterday morning. Here are the others since we have been using the fiber.
    May 2016
    macon ga
    20
    Sorry, forgot to post my numbers.
    FC 2.5
    CC .5
    ph 7.4
    CYA 35
    TA 100
    Sep 2013
    Charleston, SC
    540
    So to go back over this, you pass the SLAM when you have met these three criteria:
    Crystal Clear water
    Pass the OCLT with less than 1 ppm FC loss
    CC less than .5
    If your water isn't clear, then you should still be at SLAM level which would be 16. Have you maintained the level of 16 consistently for three weeks? If so, we will look at other issues, but with a FC of 2.5, you are way under your SLAM level.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    For some reason when I opened my pool this year it stayed cloudy longer then expected. I just put some clarifier or something like that in and it was clear the next day. No issues in the 2 months since.
    2008 23K IG Liner, Pentair intellipump vf, 48DE filter, Heatpump, SWC, aquabot turbo T, K2006 Testkit
