Results 1 to 11 of 11
Thread: Polaris 360 / use main pump or water feature pump
    Sep 2014
    Wharton County, Texas
    32
    When we built our pool, we purchased the Hayward TigerShark robotic cleaner thinking that was the way to go. It's a hassle for us with our schedule to run it most of time so I purchased a Polaris 360 thinking we could run it with the pool pump. It'd be nice to have the Polaris run daily withot us having to intervene other than cleaning the bag every once in a while. We have a Hayward VS-3200 variable speed pump that I run full speed for 5 hours then 50% for a few hours. A dedicated return was run for an external cleaner though that is just capped off at the equipment. We have a 1.25 hp water feature pump feeding 4 3/4" spouts of a weeping wall and a tanning ledge bubbler.
    I tried hooking the 360 to a pool return, but it didn't seem to have the pressure required to move it properly. I don't seen an option to limit pressure to the other returns so I don't see us as being able to run it off our main circulation pump efficiently.
    I hooked it to our tanning ledge bubbler that's on a different pump and it moved pretty good from there.
    My options that I see are:
    1. Plumb a tee into our water feature pump with a ball valve that I can control flow, and program that to run a certain time daily through our Controller.
    2. Plumb a Tee into the suction side of our water feature pump and purchase a booster pump and use an external timer. (Not sure if the 360 will handle the booster pump pressure)
    3. Plumb a Tee into the suction side of our water feature pump and purchase a booster pump and purchase a Polaris 380 or high pressure cleaner.
    Option 1 is obviously the cheapest route. The water feature pump is a 1.25 hp by Century and I would guess should handle the weeping wall and tanning ledge bubbler along with the cleaner?
    Any suggestions?
    Thanks!
    19K gallon free-formed w/ 60% Color Quartz plaster
    3.5' x 5.5' x 4' depths - 15' x 20' 15' widths - 12" oval raised spa with spillover
    Hayward 1.85 hp TriStar VS Pool & 1.25 hp water feature pump - Cartridge Filter
    Hayward OnCommand automation system - 400K BTU heater - LED lights for pool & spa
    20' weeping moss rock wall - 5' x 8' tanning ledge with bubbler
    38,516
    Re: Polaris 360 / use main pump or water feature pump
    Sorry for the delayed response.
    You need a way to force the pressure to the cleaner (it will NOT run with a booster pump, so 2 and 3 are not an option).
    I would suggest plumbing in the dedicated return line to the return of one of the pumps (I would probably put it on the main pump) with a valve that you can set the appropriate pressure. You might even be able to add an actuator on the valve that your automation would control to only have the cleaner run when the VS pump is on high speed.
    Sep 2014
    32
    Thanks. So to clarify if I put a tee into the line coming out of my main 1.85 hp pump, with a ball valve running to the 1-1/2" pipe that's capped, bottom right, my pump should handle it? I suppose i could just run the pump longer on high if flow is reduced to returns.
    38,516
    No, you need the water to the pressure cleaner to be after the filter.
    And you would not use a ball valve, use a 3-way valve (like in front of the pump, but without the actuator) so you can force enough water to the cleaner.
    Sep 2014
    32
    So it would need to be after the filter but before the heater?
    Put a tee, or 3-way valve just to the left of that elbow coming out of the filter?
    38,516
    Or after the heater. Do you have a spa? Is that what your automated valves are for? Might make sense to have the pressure cleaner come off the pool side of your return valve. Maybe right where that chlorinator is that you can cut out and throw away
    38,516
    Don't use a tee. It may not force enough flow to the cleaner.
    Sep 2014
    32
    Yes, we do have a spa. That valve on the left controls the spa/pool.
    I'll have to see if I can fit a valve under the chlorinator.
    Thanks for the help. I would have cut it in right behind the pump.
    38,516
    What do you mean by cut in right behind the pump? I was suggesting putting a valve instead of the chlorinator.
    Sep 2014
    32
    Yes I understand that part. Had you not responded I probably would have put a tee behind the pump with ball valve and had problems. Lol
    38,516
    Ah, I see.
    The three-way valve can really go anywhere after the filter it could be before the heater or after the heater but generally you have all your pool related Returns on one side of an automated valve and all your spa related ones on the other.
