Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Please explain "sparkling"
    Aug 2015
    Apex,NC
    76
    Ok, I'm an engineer...
    Can someone explain what is meant by "sparkling" water?
    I understand water clarity. It can easily be measured. Does "sparkling" mean "apparently perfect" clarity?
    Or is this referring to reflections that occur on water ripples when the sun is shining?
    If it's the latter, how/why does "sparkling" depend on water chemistry?
    Thanks!
    Aug 2010
    Dallas, TX
    4,052
    Re: Please explain "sparkling"
    Refraction and reflection of sunlight. When the water is properly balanced and extremely clear, it will sparkle. Think of a very clear diamond vs. an occluded gem.
    Between the look and smell of the pool water, I can tell if everything is in balance without testing.
    And yes, I still test.
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Does pH affect the look of the water? I thought I read that somewhere.
    -Paul
    15k gallon IG plaster, 26x39 at widest points, sort of shaped like the great state of Texas!
    B2854 Pentair Challenger 1.5 HP single speed motor
    Tagelus TA-60 Sand Filter, Polaris 280, TF-100
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I still want a "like" button. Well said RobbieH!
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    470
    Here is my pool sparkling:
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by paulmaz View Post
    It can. If pH is off, I have found that it can cause cloudiness, especially if CH is high. If I walk out and my water isn't sparkling, pH is the first culprit that comes to my mind, and most of the time it has been the issue. That or I haven't been running my robot.
    This is an old picture before the deck grout repair, replaster, and new waterline tile, but this is my idea of sparkling. Note, that main drain you see there is 9 FEET below the surface.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Another one
    When it's calm it looks empty, when it's rippling it looks like a diamond.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Aug 2015
    Apex,NC
    76
    So, can the water clarity be identical, but one pool "sparkle" and the other not?
    So "sparkle" is just a synomym for extremely clear?
    What I think of as "sparkling" depends not only on water clarity but on pool bottom color, ambient light, and surface wavelets. Reflections, in other words.
    Asking a different way, if water clarity between two pools is identical, can one sparkle and another not? Because of ph? Any theory behind this?
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    124
    Good explanation and picture Robbie! That's what I had in my mind when I referred to sparkling water in another post...
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by davethomaspilot View Post
    Yes, as stated above. If balance is off, including pH, it will make a difference. And as stated, if pH is off, it can cause clouding, especially if CH is high. I see cloudy water, I immediately think pH.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Funny how I knew that just by reading the thread title! engineers!
    Isolated Spa - 345 Gallons
    Aug 2010
    Dallas, TX
    4,052
    "Is the glass half empty or half full?"
    Engineer: It has a 50% safety factor.
    Oct 2015
    San Diego, Ca.
    646
    A Pool Guy: The glass is twice as big as it needs to be.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by Philo View Post
    I was thinking he would say "Throw a trichlor tablet in it and it'll be fine"
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    LOL!!!!!!!
    In the words of Emeril. Sparkling is ANOTHER notch, TFPC style. Once you see it you will know. I have sparkling water pics and stupid clear night time pics in my build thread below.
    Aug 2015
    Folsom Prison, CA
    124
    Friggin engineers... lol
    Jeff || 19,000g IGP || SwimClear 3025 Cartridge Filter || Hayward TriStar 1.39 THP pump || K-2006 Test Kit || 80% Surface Coverage Heliocol || Hayward Controller || Hayward Phoenix 4X4 || "Solar Rings" || PoolSkim
    Jul 2009
    Long Island, NY
    267
    Quote Originally Posted by RobbieH View Post
    Well said. I do the same. If I'm in the water and get my nose right down to the surface, I can smell if there is a problem. The other side of having perfectly clear water is that you can see every spec of dirt (or liner wrinkle) on the bottom and that can drive a person crazy!
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Aug 2010
    Dallas, TX
    4,052
    Took some pics tonight. Reminder, that robot is 9' under. If you look closely, you can see the stone and shell in the Primera Stone even in the deep picture. Those are TINY stones. (and polished!)
    DFW, TX
    24,496
    Nice pool!
  20. Back To Top    #20
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by Mr Bruce View Post
    Another one
    What is floating in your pool?
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
