Thread: Need a new blower for the attached spa, recommendations?
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    I have a 16 year old Polaris 1-516-03 blower mounted on a 2" pipe for the attached spa to my pool. Motor is going bad and I'd like to replace it. Any recommendations for a comparable one (1.5 HP, 4 amps) that is quieter than this thing?
    I may run the piping further from the pool and behind the filter to get the noise level down, but this thing is obnoxious.
    28K gallon, raised beam, plaster/ceramic color quartz with attached spa. TF-100 test kit
    Hayward 1.5HP super pump, DE4800 DE filter, Hayward inline chlorinator w/3" tabs (off)
    Pool: 2 floor drains, 2 skimmers, 3 floor returns, 2 wall returns, 3.5' deep > 8' deep
    Spa: 2 floor drains, 4 jet returns
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Need a new blower for the attached spa, recommendations?
    Have you ever tried running the spa jets without the blower attached (completely removed an open ended pipe)? Sometimes spa jets will work just fine without it. How far is the blower from the spa?
    Mark
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Mark,
    Yes I tried that today. Makes no real difference. With the plumbing diverted to spa only, the 4 jets produce some decent flow and bubbles, but no different than with the blower mounted to the pipe or removed from pipe.
    We like the turbulent action given from the blower, but opt not to run it at times because it is so darn loud. Now that the motor is failing, I 'd like to replace it with a quieter version.
    The standpipe where it is mounted is approximately 30' from the spa.
    May 2014
    Safety Harbor, FL
    4
    My Air Supply Silencer blower is much quieter than the one it replaced. Can be purchased from Amazon.
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Thanks shoeboo. I sent them an e-mail today asking for a plug-n-play replacement for the one I have now that would be spec'd the same. Reviews online for their various silent spa blowers all appear to be good and very quiet.
    Nov 2015
    Carrollton tx
    451
    I replaced my 1.5 hp jandy recently with a new QT model and it was a BUNCH quieter
    I would guess half as noisy or less
    And really easy to install
    I think the QT helped but also the sound insulation in mine was so old it was dust
    you can see the old one at the top of this picture
    Here is new one from web
    QT Residential Blower
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
