Results 1 to 10 of 10
Thread: Correct boric acid?
    Nov 2011
    Southern Nevada
    14
    Correct boric acid?
    Going to try borates this year. Will this boric acid be ok?
    First time pool owner. Fired pool guy in mid 2014. Purchased home w/ plaster 14,500 gal 16x32 inground + spa, all newer Pentair equipment.
    Test kit: Taylor K-2006 Pump: Intelliflo variable drive # 011018 4x160 Filter: Triton Fiberglass Sand Heater: MasterTemp
    Aug 2010
    Dallas, TX
    4,052
    Re: Correct boric acid?
    Strange, how does 99.6% plus 17.4% add up to 100%?
    Here's the one I buy
    Granular Boric Acid, 55 lb [boric55] | DudaDiesel Biodiesel Supplies
    Just check the prices.
    JoyfulNoise's Avatar
    May 2015
    13,247
    Correct boric acid?
    Quote Originally Posted by RobbieH View Post
    It doesn't. Those are not separate ingredients. It's telling you that it's 99.6% boric acid (H3BO3) which has the equivalent boron concentration (B) of 17.4% in boron units [B]
    That stuff will work just fine. If you check the grain size, that would be helpful. You don't want a fine powder.
    Matt
    Aug 2010
    Dallas, TX
    4,052
    I figured as much, it just looks funny.
    Nov 2011
    Southern Nevada
    14
    I can get a 50 lb fine powder from fleabay $60 or 50 lb granule $94 from Duda. I'm not accustomed to using chemicals that doesn't add up to 100% or real close. Thank you for the explanation JN.
    May 2015
    13,247
    Quote Originally Posted by Hoover Dam View Post
    You want the granular boric acid not the fine powder. The fine powder will gat blown around by the wind and sit in the water surface. Granules will sink and mix better.
    Matt
    Aug 2010
    Dallas, TX
    4,052
    I should have mentioned, even though I posted the link to Duda, you can buy from Duda off of eBay for less than direct from Duda for some odd reason. Last time there was a $20 difference including shipping.
    Jul 2015
    Western NC
    115
    Links or it didn't happen.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    Nov 2011
    Southern Nevada
    14
    Well.....I ordered granule from Duda but received the fine powder. I could have acquired fine powder from another source for $34 less, so this is annoying.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    It will work. Maybe mixed it up in water first them put pour in.
