Thread: Newbie Mistake
    Mar 2016
    Tampa, Florida
    93
    Newbie Mistake
    New to the forum as well as new to owning a pool. Great information here and purchased a Taylor 2006 test kit in hopes of monitoring my own chemicals and learning from this site.
    That said. . . I think I made a newbie mistake in that when I tested the pool yesterday it showed I had no free chlorine. I then noticed that the chlorinator on my Omnilogic was off. I believe it has been off since Sunday when I apparently hit a button accidentally. My Fcl and Tcl have been around 3 up until this error.
    My question is - will turning on the super chlorinate mode or upping the percentages manually on the chlorinator to 100% slowly get the chlorine level back or is pouring liquid chlorine into the pool also necessary?
    Gallons 13,860 / IG Pebble / Hayward OmniLogic / Hayward Swim Clear Filter / Hayward EcoStar / Hayward TriStar VS (for water features) / Hayward HeatPro Heat Pump / Date of build 3/11/16 / Other features: Spa / Hayward Colorlogic LED lights (2 in pool / 1 in spa) / Pentair LED Bubblers (2 one on each sun shelf) / Pentair Color Cascade Laminars (4 around pool) / Taylor K-2006 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Newbie Mistake
    If you have no algae, just turning on the SWG will slowly start building the FC, assuming you have some CYA to protect it from the sun. If you have some bleach on hand, take FC up to your normal setting and let the SWG carry on as normal. If you don't, set the thing on boost so you get some FC in the water before you do get algae.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: Newbie Mistake
    I'd pour in a gallon of bleach first and then crank up the SWG to be on the safe side.
    Mar 2016
    Tampa, Florida
    93
    Re: Newbie Mistake
    Thanks fo the responses. Checked the water and using super chorinate for the last 24 hours has gotten the FC and TC back up to 4.
    Richard320's Avatar
    Jan 2010
    18,988
    Re: Newbie Mistake
    Quote Originally Posted by Lawtyger View Post
    Excellent!
    There's a common misconception that the instant a pool dips below the minimum Fc that the pool will explode in green algae. I see a pool as a living thing. Like a human, it might not be happy to fast for a day or two, but if it's generally in good health, no permanent damage will happen.
