Thread: Handrail considerations with SWG?
    Sep 2015
    Atlantic Beach, FL
    70
    Should a salt water pool have a particular type of handrail?
    Thinking about corrosion and/or electricity conduction ...
    8K gal 13'Wx19'L IG kidney. 3.5' to 5'6" depth. Pentair: Ultratemp 120 heater/chiller; Intelliflo 2 VS pump; Intellichlor IC40 SWG; cartridge filter; EasyTouch controller. 3 wall returns, 1 skimmer, 1 cleaner line. Tremron Oak Run coping and pavers. Noble Tile Toscano waterline. Marbletite's Freestone pebble in St. Thomas. TF100 and K1766 test kits.
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Re: Handrail considerations with SWG?
    I did research before specifying the handrail I wanted for my pool under construction.
    PB didn't install the one I had in the contract. It was to be MARINE Stainless Steel because I will be going to SWG later.
    You can read about handrail choices and installation in my thread:
    Handrail in Pavers
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    Sep 2015
    Atlantic Beach, FL
    70
    Thanks!
    Aug 2010
    Dallas, TX
    4,052
    In case you don't know, ocean water has 10x the concentration of salt that you will have in your pool, 35,000ppm vs 3,500ppm.
