Thread: Adding Jacks every other week with TFP method
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    I am almost one week into my new pool being opened. I've been adding bleach as needed and everything else is in line. Crystal clear. Just for grins, I have been reading back to the pool company's maintence manual and in addition to adding pucks and algaecide on a schedule they recommend adding Jacks every other week for stain prevention.
    I have a well and initial analysis shows slightly high iron (no staining in sinks or toilets though) and I was envisioning adding 6oz of Jacks Pink stuff every other week as stain prevention. My pool company's guide ( that I am not following for anything else ) says to add 6oz every other week.
    My question is: can I screw up any other levels by doing this sort of preventative treatment or should I just sit back and see if I even get staining? I wouldn't mind pouring some jacks in every now and then if it kept my well water from being damaging but if Jacks on a routine basis and my current bleach TFP program don't jive together then i won't.
    Thoughts?
    John
    27,000 gal concrete rectangle, built Oct '15, DE filter, Jandy PHPM 1.5 HP, Hayward HP21104T heat pump, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Adding Jacks every other week with TFP method
    Adding Jacks is fine, but no need to add more until you see metal stains again. As soon as you start to see a stain add more and it will lift the stain and keep it sequestered.
    More here, Pool School - Metals in the Water and Metal Stains
