Results 1 to 14 of 14
Thread: What naturally (not which chemicals) lowers pH???
    Smartjack's Avatar
    May 2016
    Naperville, Il
    124
    So, I am new to the TFP method, and loving it. Before finding this site, I was using only DiChlor in my pool. That took my CYA out of control (which is what brought me here), but also always kept my pH low. I was always buying tons of pH up, and always seemed to have a low pH, no matter what I did. So, I know that will end this year. Now, using the TPF method, I will be adding bleach, and not lowering pH with my DiChlor. So, on to my question.
    I know that aeriation (splashing, return jets rippling water, etc) will increase my pH. I also know that acid will bring my pH down, as well as rain water, since rain is acidic. But, will any other NATURAL occurrence lower my pH?? From what I see, it looks like I will never need to add something to bring my pH up again, and should be keeping plenty of acid on hand going forward with the TFP method.
    Am I missing something here? It would seem after opening, and once I achieve proper balance, I will only be lowering pH, unless we get tons of rain dumped in the pool.
    Bruce - (The SmartJack was an invention of mine, and became my nickname)
    Fox Pool 40x27 IG Vinyl, Lagoon Shape, 27,000 gallons, Hayward 300,000 BTU heater
    Hayward 1.5 HP, 2-Speed SuperPump, with Hayward C4025 Cartridge Filter
    Polaris C-310 ORP Controller, modified to pump Liquid Chlorine
    Hayward Phantom, and Aquabot Turbo T-Jet automatic pool cleaners, Taylor K-2006
    Oct 2015
    Austin, TX
    83
    Re: What naturally (not which chemicals) lowers pH???
    If you're worried about toxicology, Muriatic Acid (AKA Hydrochloric Acid) is about as simple a chemical as you can get. One hydrogen atom, one chlorine atom. Both of those atoms are in your pool anyway...
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Smartjack's Avatar
    May 2016
    Naperville, Il
    124
    I'm not worried about adding Muriatic acid. I'm just curious if I am done with pH up (or Borax now that I am on the TFP method).
    For 8 years I have never needed to lower pH, because the junk I've been dumping into my pool has always been lowering it. Now that I will only be using bleach, which is pH neutral, I'm just curious if I am done every needing to raise pH (other than at a opening, or after a major storm). From what I am reading, it seems like my pH will always be rising, unless there is something else in nature that drops it. So, I thought I would ask what naturally lowers it.......
    38,275
    It is very likely that you will not need to raise your pH anymore. I am not aware of anything that naturally lowers the pH besides what you've mentioned already.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I haven't added anything to increase my ph in 9 years.
    22,548
    Ditto what FPM said. I also haven't used but a few cups of acid in the last 8 or 9 years. My pH sits dead on 7.5. I said that to say, don't imagine problems that may not exist. You may find that your pH is very stable.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Quote Originally Posted by frustratedpoolmom View Post
    +1 to that!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    ya once you figure out what your pool prefers for TA level, you can get it to stabilize ph levels.
    both my first plaster pool and current vinyl in ground have ph at 7.5 all the time with no swings.
    Dolphin E10 Cleaning Robot.
    Smartjack's Avatar
    May 2016
    Naperville, Il
    124
    What am I going to do with all that money I'm not spending on chemicals this year??????
    38,275
    Quote Originally Posted by Smartjack View Post
    Up your supporter level?
    Donldson's Avatar
    NW Ohio
    2,893
    Get something for nice for the Mrs to really grease the wheels of the TFPC acceptance train
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Quote Originally Posted by Donldson View Post
    +1!!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Smartjack's Avatar
    May 2016
    Naperville, Il
    124
    She's going to be getter the most beautiful pool water she has had in 8 years. What more could she want???
    I just used the first months savings to order a pump for liquid chlorine. Once I get that hooked up to my watermatic, I change my signature from "uses DiChlor"
    DFW, TX
    24,485
    Liquor store for fruity, beachy drinks and floaties!
    How come I am the only one with the right answer???
