Thread: Waterline tile fix
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Waterline tile fix
    This morning the PB is meeting the new tile guy here to go over "fixing" my bad waterline tile job. I'm nervous about it. I had wanted the whole thing redone but as of yesterday evening, it sounded like they are just going to "fix" the bad areas.
    Besides the esthetics of a straight, even, well applied and grouted tile job, what else do I need to look for?
    I have some experience doing ceramic and marble tile, but not pool tile.
    Can a bad tile job cause a pool leak?
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Waterline tile fix
    Yes, water can leak if not grouted properly, but not a lot. If the grout looks good it generally doesn't leak. Tile is mostly about being level because we know the water will be.
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Thanks for the answer!!
    Denise-TFP Guide
    30,421
    Most problematic may be matching the grout color. I would get reassurance in advance
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    From what I saw in the pictures you posted it looked like they started at an inside corner and finished at an outside corner. That leaves cut "slivers" of tile or very wide grout very visible at the outside corner vs being tucked into the inside corners. I don't see how replacing a few tiles will fix the problems you were showing, unless they are planing to redo a whole wall.
    chiefwej
