Results 1 to 16 of 16
Thread: Spa Light keeps blowing GFCI
    Dec 2015
    Chino/CA
    203
    So, I go outside to brush the pool down and I flip the both pool and spa light, then they shut off........ok, weird. The pool light will stay on and doesn't trip the GFCI........turn that off and turn the spa light on and almost a second later it trips the GFCI every time. I replaced the bulb back in Dec. when I put it back in I broke the little piece that the screw goes inside of the niche. What could be the problem?
    Is this an issue?
    Chris B.
    New house w/ 28 y/o I.G. 15k gal. pool/spa, Plaster, Hayward DE-480S Micro Clear Filter, Pentair Whisperflo wfe-4, 1HP (Main Pump), Hayward SP2815x20 (Pump for spa jets), Versa Pool Heater, Hayward Pool Vac Ultra, TF-100 Kit
    Rondanick's Avatar
    Apr 2016
    Mount Juliet, TN
    11
    Re: Spa Light keeps blowing GFCI
    My pool lights are doing the exact same thing. We changed the GFI thinking that was the problem and it wasn't. I wonder if water in getting into the unit. Our lights are the color logic by Hayward and are not cheap. The pool store says they are just bad and we need to replace them. They are ten years old. I'd like to know if it's something we can fix.
    Ronda
    my pool is a 18x36 inground with Romans style ends. 8' deep with steel walls and a vinyl liner. 26,730 gallons
    Apr 2013
    Sacramento, CA
    2,769
    I doubt it's the retaining ring.
    I would take the fixture out and the bulb. Look close at the fixture. Replace the bulb carefully making sure it seats correctly. In a perfect world I would replace the gasget too.
    If that doesn't work I would open up the J box and inspect. Is everything connected and tight? Is there slack in the cord?
    Apr 2013
    Sacramento, CA
    2,769
    Ten year old color logic led lights? I suspect replacement is in the cards. There are YouTube videos on how to do it. Watch a few, if you feel you have the ability then do it. We can answer questions and guide you.
    Dec 2015
    Chino/CA
    203
    When I opened it up back in Dec. I changed the gasket because it was pretty bad, its been working fine for the past 5 months. The only thing I did was last weekend I drained 50% of my pool water, including the water in the spa. Im wondering if the drain/re-fill of the water moved something???
    This are the pics of what it looked like when I took it out:
    Chris B.
    Dec 2015
    Chino/CA
    203
    I wont' be able to open her up until tomorrow morning, but Im already thinking about replacing the entire fixture, I've been looking at the exact replacement part (Pentair 78106000) but am starting to think about LED........
    Whats the pro's/con's of going LED
    My main pool light is still incandescent, if the spa light is LED, would it look weird?
    I really dont want to spend more than $500, what are my choices?
    Are there any changes on the electrical side if I go LED?
    Chris B.
    Apr 2013
    Sacramento, CA
    2,769
    The main con of LED is that they appear to not be as bright but that probably does not matter in a spa. I doubt it will look weird.
    Color changing LEDs can be installed with out any special wiring changes they are just a pain to change colors. There are some with remotes that makes that easier.
    Go look on Inyo pools and Sunplay, Amazon etc and compare prices. I have Jandy which I like but Hayward and Pentair are just as good.
    Changing the fixture means disconnecting the cord at the junction box and pulling cable through the conduit. Watch a couple of You Tube Videos (I really think Inyo has one) and if you don't think that's for you hire an electrician or a pool service.
    Aug 2015
    Folsom Prison, CA
    124
    If you replace it, remember to leave the current light in place until you are read to swap so you can use the old wire as a pull cord.
    Jeff || 19,000g IGP || SwimClear 3025 Cartridge Filter || Hayward TriStar 1.39 THP pump || K-2006 Test Kit || 80% Surface Coverage Heliocol || Hayward Controller || Hayward Phoenix 4X4 || "Solar Rings" || PoolSkim
    Dec 2015
    Chino/CA
    203
    On Friday morning I started the mission that I accepted, I 1st went to Home Depot and bought a replacement GFCI, that took some time because I had to figure out the wiring!!!!! After a couple of hours messing around with that (I hate dealing with electrical and plumbing, so this is like both!!) I came to the conclusion it was the light. Went to the local pool store, got a light and a pool light wedge, came back home and started the tear down process. I disconnected the old light and before running the line I connected it and bingo!!!! The GFCI didn't trip anymore, so at that point I definately knew it was the light. So, continued by tying a small braided rope to the old light cord and pulling the new one thru, that was fun......NOT!!! LoL
    So get everything buttoned up and back together and I now have my spa light back and the GFCI doesnt trip.
    One question, I seem to have one of these in my spa and 2 of them about the middle of the pool on both sides, what are they for?
    Chris B.
    For the spa I'm guessing its to tie a thermometer to, now for the pool, it's to tie the floating ropes ( guess that's what you'd call them) from one end to the other to denote the shallow end of the pool from the starting of the deep end.
    17.5K IG Pool with Spa spillover and fountain, Plaster Finish, Purex Triton CC420 Cartridge Filter, Pentair Intelliflo XF VS motor, Laars LX GasHeater, Polaris 360
    Apr 2013
    Sacramento, CA
    2,769
    Generally they are used for tying small children to the pool wall so the pool can be used as intended for the parents.
    Quote Originally Posted by gwegan View Post
    LOL!!!!!!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Isolated Spa - 345 Gallons
    Dec 2015
    Chino/CA
    203
    HAHAHAHA!!! Nice!
    Anyone else have any cleaver ideas on what they could be used for?
    Chris B.
    Houston, TX
    1,107
    To tie your ice chest
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    wjr75's Avatar
    Jun 2013
    IL
    836
    We have them in our pool for a floating rope as indicated above. We have never used it.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
